Author Topic: Clay Mitt's ???  (Read 1383 times)
Offline wagonboy
  • Nov.2007 ED30 dsg reflex silver
Clay Mitt's ???
« on: August 13, 2014, 09:40:54 pm »
 Are the clay mitts already impregnated with 'clay' and will they remove very fine scratches prior to giving the car a good final polish. Be very interested in your valued comments, thanks. Also how long do they last .....is it just once over the whole car or do you give it a good wash and be able to perhaps do it again at a later date. Cheers for any input.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Clay Mitt's ???
« Reply #1 on: August 13, 2014, 10:34:30 pm »
Clay will certainly not remove scratches. You need a polish with compound to remove light scratches in the clear coat.
'07 Red manual
Offline Gman30
  • Mk1 GTI to a MK5 GTI Edition 30
Re: Clay Mitt's ???
« Reply #2 on: August 14, 2014, 12:23:58 am »
Not used the mitts as yet but the idea behind clay is to remove slightly embeded contaminates from the paint work.
As the lubed clay pass'es over your lacquer they're cought and picked up by the clay. As previously said, no scratches will be removed by this and you can incur more.. the idea is that you leave a nice clean surface to then polish any scratches or defects out and or then protect with a wax or sealant. Clay doesn't remove any lacquer so you do it as required to keep your paint smooth/contaminate free, machine polishing is what removes a fine layer of lacquer hence being able to polish scratches and defects out.
A properly decontaminated car is a lot easier to work on!
Hope this makes sense!
Offline wagonboy
Re: Clay Mitt's ???
« Reply #3 on: August 14, 2014, 08:15:13 am »
Thanks for replies   :happy2:
