Author Topic: Speaker upgrade  (Read 1390 times)
Speaker upgrade
« on: August 15, 2014, 09:57:28 am »
Without using amps and what not is there an improvement to be had by replacing the oem door components with upgraded ones such as infinity etc?
I've read the 2-3 way ones require the snipping of the wire that goes to the tweeter in the door.
Is it pointless to replace them if not bothering with amps & XOvers? The head unit is a Sony 4x 52w  :happy2:
Offline xjay1337
  • -Receive: 377
Re: Speaker upgrade
« Reply #1 on: August 15, 2014, 10:24:36 am »
Yes you will have to cut the wires...the stock crossover units are poo.. I have Hertz ESKL163.L in my fronts... mids are a very tight fit so aren't in yet...but tweeter and large speaker are... crossover unit is nice and easy to do for anyone capable with audio.. big improvement.
Re: Speaker upgrade
« Reply #2 on: August 15, 2014, 10:53:43 am »
Really not fused about adding any more kit if it's not necessary, just wondering if there's a half decent improvement to be had by simply swapping the speakers of if it's just money wasted?  :happy2:
Offline xjay1337
  • -Receive: 377
Re: Speaker upgrade
« Reply #3 on: August 15, 2014, 12:01:57 pm »
If you're going to bother fitting upgraded speakers then you should fit whatever crossover box comes with your uprated speakers. As proper ones do not come as a "clip" connectors.
You would get an improvement anyway, but you'd get more of an improvement with better wiring.  :happy2:
Re: Speaker upgrade
« Reply #4 on: August 15, 2014, 12:10:12 pm »
Offline Grande_GTi
  • -Given: 41
Re: Speaker upgrade
« Reply #5 on: August 15, 2014, 03:06:05 pm »
Get in touch with BLADEICE, got some cracking deals on Gladen bits atm
instgram @ricky_grande
check out @lowlife_official
MK5 GTi OEM+
Offline Furbo
Re: Speaker upgrade
« Reply #6 on: August 19, 2014, 01:04:13 am »
If you like your music, it's definitely worthwhile upgrading the speakers - and as already pointed out in previous post, change the crossovers as well with the ones that come with new speakers.
Up to you if you go 2 way or 3way - as also mentioned above, swapping the mids can be tight, but some do fit without need for modifying anything.
If you already have the 3 way, even upgrading to a half decent 2 way set up will drastically improve the sound! I know others who have simply fitted new speaker wire behind the door card, leaving the original wiring unused and in tact? Easy enough to do.
I would also recommend adding a little sound deadening around the bass driver as well, if you have the door card off anyway. This alone will greatly improve the sound  :happy2:
Offline simonp
  • -Receive: 38
  • No longer a Golfer
Re: Speaker upgrade
« Reply #7 on: August 19, 2014, 07:59:18 am »
Heard good things about this kit. Woofer is 8" instead of 6.5".
