Author Topic: Dv again!!!  (Read 3032 times)
Offline th3_f15t
  • -Receive: 183
Re: Dv again!!!
« Reply #15 on: August 15, 2014, 11:40:40 pm »
Just get a GFB DV+ fitted, no diaphragm to fail and works better than either stock parts.
Offline mac456
Re: Dv again!!!
« Reply #16 on: August 16, 2014, 12:19:14 am »
Standard gti here, is it worth changing? Think mine is stock and done 79k
how easy is it to change? Any guides? Tempted to book it in at the indy
Offline Tazgti5
Re: Dv again!!!
« Reply #17 on: August 16, 2014, 04:28:29 pm »
Change it mate, the difference is unbelievable  :driver:
Offline Black9
  • -Given: 35
Re: Dv again!!!
« Reply #18 on: August 16, 2014, 05:32:58 pm »
My KO3s been running the original rev A since new in 2005 without any issues. Stock engine tho
My KO4 ran the original rev G since 2007 without issues and REVO software most of its life without needing replaced
Not sure why some fail and others don't
Offline Tazgti5
Re: Dv again!!!
« Reply #19 on: August 16, 2014, 05:54:39 pm »
Maybe if your cars modded than ,
I'm on stage 1
This is probably why it's killing the dv? :fighting:
« Last Edit: August 16, 2014, 06:00:01 pm by Tazgti5 »
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Dv again!!!
« Reply #20 on: August 16, 2014, 07:10:33 pm »
DV+ is twice the price of an OEM DV and has been proven to leak (although more so on K04 setups).
Rev G is still the best. May be cheaper to buy a DV relocation pipe and a new OEM rev G DV and have the reassurance that it should last well and not leak  :happy2:
Offline Bazgti
Re: Dv again!!!
« Reply #21 on: August 16, 2014, 07:11:59 pm »
So i have stage 2 apr software, full miltek turbo back and neuspeed CAI. I last changed my DV bout 3 1/2 years ago. Which revision would people recommend? Mines feeling a bit sluggish at the mo so its the cheapest and quickest thing to try and replace 1st in a whole list of bitty bits of crap that could be failing.
Offline Sug
Re: Dv again!!!
« Reply #22 on: August 16, 2014, 07:51:49 pm »
Rev D ko3
Rev G ko4
EDITION 30 GONE, MK6 R GONE........AUDI 8V S3.....Stock for now
Offline s4seeker
Re: Dv again!!!
« Reply #23 on: August 16, 2014, 08:06:58 pm »
After asking advice in another thread I've gone rev g on my standard gti.
What a difference if a bit fiddly to get at.
Will be checking at each oil service now i think.
Offline Bennz
Re: Dv again!!!
« Reply #24 on: August 17, 2014, 08:47:45 am »
I find with my car when I do lots of city driving the car becomes sluggish, so I do throttle reset and it makes a good difference.
Offline Bazgti
Re: Dv again!!!
« Reply #25 on: August 17, 2014, 08:49:37 am »
How do you do that?
Offline Matthewsimone
  • -Receive: 39
Re: Dv again!!!
« Reply #26 on: August 17, 2014, 09:16:54 am »
Yes whats this throttle reset you speak of  :confused:
Offline Bennz
Dv again!!!
« Reply #27 on: August 17, 2014, 11:36:05 am »
This is what I do :
Turn on the ignition ( don't start the engine) and wait all lights stop flashing , then
Floor the gas pedal
Hold it for 30 sec then let it off ( for some it could work when you keep holding the the gas pedal, turn off the ignition then release the pedal)
This is different to the method which you can reset the throttle (ECU) via vagcom
Offline Adrenaline
Re: Dv again!!!
« Reply #28 on: August 28, 2014, 11:49:59 pm »
Youd better get the revision D it will hold fine from stock to ko4 more then that go with a forge Dv or gfb Dv+
