Author Topic: Cold Air Feeds In Fog Grills  (Read 13876 times)
Offline Callum45
« on: August 17, 2014, 03:17:38 am »
Looking to fit some cold air feeds to my car and plan to run them through the fog cover.
Does anyone have any pictures of some fitted and links to the ones they have used, thanks
Offline Stevepd
  • -Given: 49
Re: Cold Air Feeds In Fog Grills
« Reply #1 on: August 17, 2014, 08:23:57 am »
I removed the boxed item at the grill and the tapered bit that is clamped to the rigid plastic. I the fitted 80mm cold air tube to the tapered bit bring the tapered bit forward against the original intake = works a treat. I 'll throw up a photo later.....
Steve.
Standard 5 Door Shadow blue.
  • -Receive: 427
« Reply #2 on: August 17, 2014, 09:18:10 am »
Mine (below). More pics, parts used etc etc in my build thread....
Offline Tazgti5
« Reply #3 on: August 17, 2014, 02:32:42 pm »
This looks good,can we see some engine pics just to see how u feed the pipe.
Offline J400uk
  • -Receive: 27
« Reply #4 on: August 17, 2014, 02:39:55 pm »
Would you not just use open air vents, or am I missing something?
Offline Tazgti5
« Reply #5 on: August 17, 2014, 02:41:26 pm »
Looking at your vents they look really good ! Are they expensive ?
Offline ED30GTI
« Reply #6 on: August 17, 2014, 04:00:28 pm »
I like the open vents , but I also like the look of the ducting feed , I need to do one of them but not sure which route to go down .  :smiley:
Offline Tazgti5
« Reply #7 on: August 17, 2014, 04:11:31 pm »
I also would like to see how the air duct is fed through the engine
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
« Reply #8 on: August 17, 2014, 05:18:19 pm »
Open vents on the fogs don't actually cool anything. Air needs to be specifically directed to where you want it to cool, hence the tubes.
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline Tazgti5
« Reply #10 on: August 17, 2014, 06:51:28 pm »
Thank you for the link, are they a good fit?
« Reply #11 on: August 17, 2014, 07:01:51 pm »
Open air vents + ducting to the air filter element and/or brakes is a win/win.
I have removed my fog lights and fastened ducting from behind the fog opening
Offline Tazgti5
« Reply #12 on: August 17, 2014, 07:04:17 pm »
Have you got any pics ?
Just yo see how to do
« Reply #13 on: August 17, 2014, 07:07:08 pm »
Can just about see it pointing onto the filter;
I'll get a pic of the grill in a bit
Offline Tazgti5
« Reply #14 on: August 17, 2014, 07:07:56 pm »
Ah I see !
Thank u
