Author Topic: HELP ED30 problem  (Read 1156 times)
Offline cander83
HELP ED30 problem
« on: August 17, 2014, 02:02:24 pm »
Hi ppl . Wondered if anyone has had the same experience . Car has been running great, wasn't to last long. Started car this morning to discover a bad misfire. Then management light came on. Ppl say plugs or coilpacks but I've recently changed both to iradium plugs and the upgraded red coilpacks. Any ideas or info would b greatly appreciated
Re: HELP ED30 problem
« Reply #1 on: August 20, 2014, 04:51:56 pm »
Most would suggest you contact/PM a member with a vcds cable for a scan and go from there.
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.msg812454.html#msg812454
Offline Spankiee
  • -Receive: 20
« Reply #2 on: August 20, 2014, 05:32:45 pm »
try standard plugs? or check the tips are a still ok
but yeah vagcom for starters
candy white edition 30
Offline audiman
« Reply #3 on: August 21, 2014, 12:20:18 am »
Iridium plugs are prone to the tips failing and/or dropping apart. Take them out and compare them
Mk5 GTi ED30 - 360ps
B7 RS4 supercharged - 650ps
Mk2 GTi 4motion 1.8T - 450ps
Offline cander83
« Reply #4 on: August 31, 2014, 07:53:09 am »
Sorted now guys . No codes. Terraclean seems to have sorted it
