November 28, 2024, 11:56:32 am
All Things Mk5
How to Guides / Troubleshooting
Changin Setting On Midline Vs Highline
Topic: Changin Setting On Midline Vs Highline (Read 1406 times)
lukemk5gti
Just look at my post count
-Given: 28
-Receive: 118
My Ride:
August 19, 2014, 10:11:12 am »
When I want to change settings such as units or duration of coming home lights on my highline clocks I just hold the up button on the right stalk for a second and it gives me the option to enter setup.
Does anyone know how to enter this settings menu on the midline clocks?
Ideally without VCDS
Thank you
usmangti
Always Involved
-Given: 23
-Receive: 28
Re: Changin Setting On Midline Vs Highline
Reply #1 on:
August 19, 2014, 10:22:00 am »
The additional menu's are not available on the midline computers only trip range etc
lukemk5gti
-Given: 28
-Receive: 118
My Ride:
Reply #2 on:
August 19, 2014, 10:41:10 am »
That's annoying.
If I wanted to go about changing untis from l/100lm to mpg I would need VCDS so?
usmangti
Always Involved
-Given: 23
-Receive: 28
Reply #3 on:
August 19, 2014, 10:44:51 am »
yeah probably, I assume its not a UK Speedo, as my midline was already set as MPG, if not may be doable through VCDS
skard
-Given: 5
-Receive: 245
My Ride:
Reply #4 on:
August 19, 2014, 11:47:22 am »
Quote from: lukemk5gti on August 19, 2014, 10:41:10 am
That's annoying.
Yes it is part of the coding in 17-instruments, you can change between different parts of the world
All Things Mk5
