Author Topic: DAB Aerial Options - OEM utilise telephone prep aerial cable?  (Read 2672 times)
Offline toms85
« on: August 20, 2014, 10:45:26 am »
Hi
I'm looking to upgrade to a DAB unit in my MY07 GTI with a sharkfin aerial - it has factory fitted telephone prep which presumably runs back to the aerial as I believe it's a differnt partnumber for GPS/telephone?. Any idea if I can use the aerial wire that goes from the telephone prep unit to the sharkfin aerial and use that for a suitable DAB aerial to avoid having to run a cable down the headlining etc). I don't use the telephone prep kit, and will be removing it...
What are my options to keep it OEM?
Thanks in advance  :smiley:
Offline paulw123
  • -Receive: 47
Re: DAB Aerial Options - OEM utilise telephone prep aerial cable?
« Reply #1 on: August 20, 2014, 01:37:45 pm »
I don't think your shark fin will have DAB in it, so you need a new one that has everthing, or change to a standard looking polo DAB aerial which will be a lot cheaper. I think the fakra phone cable could be used its just different coloured connectors, but not sure...
like this
http://www.ebay.co.uk/itm/Volkswagen-Oem-DAB-Roof-Aerial-With-Dab-Gps-6m-Cable-Rns510-Dab-Rcd510-Rns315-/281417573216?pt=UK_CE_GPS_Accessories_Software_ET&hash=item4185cb6360
or you could look into the DAB hatchback set-up...
I fitted the polo one in mine and its great  :drinking:
Offline toms85
« Reply #2 on: August 20, 2014, 03:05:14 pm »
Thanks for your reply. Hopefully I can use the phone cable will save having to run a new cable down to the radio. I'll look into the Polo aerial - is that a bee-sting aerial?
Many thanks
Offline toms85
« Reply #3 on: August 20, 2014, 03:07:18 pm »
Oh and do you have a part number for the polo aerial?
Thanks again.
Offline paulw123
  • -Receive: 47
« Reply #4 on: August 20, 2014, 05:58:09 pm »
I bought it used off someone on here, and didn't write the part number down...dooh
the polo base looks identical to standard golf base, bit boring, somehow they have squeezed in DAB circuits as well!! , you can fit any screw in antenna you want, yes the polo is more stubby and a different sized thread.
the vw dealer should be able to sort you out with part numbers, there are loads of different ones, bit of a nightmare...........
Offline golfmk5
« Reply #5 on: August 20, 2014, 09:28:08 pm »
Hello, Toms85. Sure you can use the wire from the telephone prep unit. You will need a pigtail cable like this in both ends: http://www.ebay.com/itm/Fakra-SMB-Z-5021-jack-to-plug-crimp-15cm-RG174-pigtail-cable-Neutral-coding-/221121539070?pt=LH_DefaultDomain_0&hash=item337bdeebfe. That cable is coding neutral (fakra Z), i.e. it will convert fakra D female (GSM) connector to a fakra A female (DAB) connector. However, as Paulw123 mentions you will probably need to replace your DAB aerial and for that you will have to drop the headlining anyway, at least partially.
I was doing the same retrofit not too long ago. Have a look: http://www.mk5golfgti.co.uk/forum/index.php/topic,84892.0.html
Offline toms85
« Reply #6 on: August 20, 2014, 10:45:47 pm »
Thanks very much guys, just picked up a RCD 310 DAB so will report how I get on!
Offline toms85
« Reply #7 on: August 26, 2014, 09:29:33 pm »
Does anyone know if the Polo aerial fits in place of a sharkfin as it looks smaller?
Offline paulw123
  • -Receive: 47
« Reply #8 on: August 27, 2014, 01:19:44 pm »
good point, I would assume the hole is the same size, but it might leave a mark on the paint where the polo ariel footprint is smaller, but then it might clean up/tcut out....
If I was you I would go for the german ebay OEM shark fin one.
Offline toms85
« Reply #9 on: August 28, 2014, 12:38:12 pm »
Thanks. I suppose I'm just being cheap and prefering to go for the cheaper option.. I might look under the sharkfin to see if it has left any marks before deciding
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Offline toms85
« Reply #11 on: August 31, 2014, 02:50:20 pm »
Do you have a pic of it on your car? I've yet to see one fitted to a golf mk5! Thanks
Offline paulw123
  • -Receive: 47
« Reply #12 on: September 01, 2014, 11:15:46 am »
someone on here has also painted the base the car colour, it looks really good, may even be degudodger....search it out....
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #13 on: September 08, 2014, 08:18:56 pm »
Here you go :)
Offline toms85
« Reply #14 on: September 09, 2014, 07:45:07 pm »
Looks good, thanks!
