Author Topic: Cylinder 1 misfire :-(  (Read 5285 times)
Offline mk4gti-t
  • -Given: 61
« on: August 20, 2014, 06:31:49 pm »
Earlier today i suffered what i thaught was a misfire. It only happens on WOT and under load. Scanned for faults and the only ones that came up were to do with the flapper motor issue that i already know about. Ran some logs and found cylinder 1 misfires. Possible causes? I'm thinking plug and/or coil pack. Anything else i should be looking for? Also this might sound like a stupid question but which is cylinder 1? I'm assuming it's the far left cylinder. Cheers.
Saintsteve
Re: Cylinder 1 misfire :-(
« Reply #1 on: August 20, 2014, 08:01:39 pm »
Injector is another high possibility as these cars seem to be suffering with injector missfire and un-smooth idling issues , anything over 60k miles , then add that to your list of possibles.
Number 1 will be nearest the cambelt.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #2 on: August 20, 2014, 10:18:04 pm »
Cylinders  3&4 are most common for misfires as they are closers to the PCV so get the most gunk coming in.
Try spark plugs first as they are a cheap fix, maybe swap coil packs around to see if the fault moves with the coil.
Worst case as Steve said is an injector  :sad1:
Offline mk4gti-t
  • -Given: 61
« Reply #3 on: August 21, 2014, 12:06:53 am »
Cheers for the advice. Ive ordered a set of NGK BKR7EIX so hopefully that will sort it out. By the way i'm currently running some nology plugs that i brought off a member on here. Only read bad things about them since i fitted them  :scared:
« Reply #4 on: August 21, 2014, 12:20:11 am »
It's recently come about that nologys are no longer recommended for our cars  :scared:
Offline mk4gti-t
  • -Given: 61
« Reply #5 on: August 21, 2014, 04:56:11 pm »
Plugs cleaned and gapped as it looked massive and running better than ever now. I've ordered some new ngk iridiums though as these nology's are a bit suspect now. Cheers  :happy2:
« Reply #6 on: August 21, 2014, 04:59:25 pm »
 :sick: just reminded me that backshaft motorsport charged me £65 for gapping my spark plugs  :fighting:
Found my feeler gauge since
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=mv5f08jpgggm7f7jont836gi92&/topic,19740.0.html
« Reply #7 on: August 21, 2014, 05:01:13 pm »
Jokers.
Offline audiman
« Reply #8 on: August 21, 2014, 09:43:57 pm »
Wtf!
Mk5 GTi ED30 - 360ps
B7 RS4 supercharged - 650ps
Mk2 GTi 4motion 1.8T - 450ps
« Reply #9 on: August 21, 2014, 11:02:46 pm »
Arseholes  :fighting:
