Author Topic: RNS510 Firmware question  (Read 1425 times)
Offline mrxbox360
  • My Ride: 2008 Golf Mk5 GT TDI Sport 5dr Reflex Silver Personal Enchanced
« on: August 20, 2014, 07:17:53 pm »
I want to upgrade my firmware from version 3810 on my lcd rns version d to version 4120, i have a version 4120 update cd but i got a error when i tryed using a cd burnt using imageburn, can someone pls answer the following questions.
1 - can i got direct from 3810 to 4120 or do i need to update to 4020 1st
2 - is it ok to burn the disc to cd or does it need to be on dvd using imageburn
3 - when updating do i use the same method like updating the maps ie keys out of the iginition
Thanks in advance for your help lads :wink:
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re:
« Reply #1 on: August 20, 2014, 07:27:02 pm »
Yes u can go direct
I would use a verbatim dvd and burn at 1x
Yea, make sure no key in ignition
Offline doylebros
Re: RNS510 Firmware question
« Reply #2 on: August 20, 2014, 07:33:27 pm »
Offline mrxbox360
« Reply #3 on: August 22, 2014, 12:05:03 am »
cheers for the reply's has any got a working down load link for the 4120
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #4 on: August 22, 2014, 08:19:35 am »
Something wrong there mate. LCD units were A, B, and early C. If you have a D unit then it should be an LED version.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
