Author Topic: Fitting OEM xenon headlights  (Read 9367 times)
Offline fazi123
Re: Fitting OEM xenon headlights
« Reply #15 on: August 21, 2014, 05:24:36 pm »
I had to purchase a bulb recently, and it was an Osram D2S bulb, so not the standard H7 type.
Offline K9
  • VW LifeStyle
« Reply #16 on: August 21, 2014, 05:25:58 pm »
but can i install oem halogen bulbs in then as long as i'm searching for correct xenon kit?
Offline fazi123
« Reply #17 on: August 21, 2014, 05:28:16 pm »
I don't believe you can. You should be able to put halogen bulbs in the main beam section, but I don't think you will be able to connect without the bulbs!
Offline K9
  • VW LifeStyle
« Reply #18 on: August 21, 2014, 05:31:36 pm »
soouu... how will i make this work out? i know they are oem xenon headlights, can i make it fit fit cobra xenon conv kit with d2s xenon bulbs?
edit: found this set -> will it work http://www.xenonkauppa.fi/epages/Kaupat.sf/fi_FI/?ObjectPath=/Shops/Xenon/Products/%22Muutossarja%20D2S%22
« Last Edit: August 21, 2014, 05:35:43 pm by K9 »
Offline Carpy25
« Reply #19 on: August 21, 2014, 05:45:36 pm »
you need matching starters for the oem lights IMO  , in h7 kits the starters take their trigger power from plugging male spade connectors into the h7 plug that normally plug on to the h7 bulb you wont have that in OEM xenon's , and even then you have the canbus bulb out system to deal with , look for OEM starts and bulbs then the adaptor wire will work
Rob
Offline K9
  • VW LifeStyle
« Reply #20 on: August 21, 2014, 05:56:33 pm »
so the linked xenon set wont work? they are d2s with d2s adapters :/
Offline Carpy25
« Reply #21 on: August 21, 2014, 06:14:56 pm »
normally kits have bases around the bulbs that fit h7 slots in the headlights oem xenons will have d2 slots , even if they do fit I cant see how your going to power the kit starters ,and  I bet the canbus wont like it if you get around that so you'll end up with a bulb warning light on the dash all the time
think your cheap xenon fix is looking expensive sorry , if your mates got the headlight how did he use them without starters
Rob
Offline K9
  • VW LifeStyle
« Reply #22 on: August 21, 2014, 06:21:12 pm »
if i buy the aftermarket cobra xenon d2s that comes with adaptors and ballasters etc, everything needed i guess. the buld itself is a d2s based, so dosnt it go stright into the oem place?
edit: if i buy 2x these bulbs http://www.xenonkauppa.fi/epages/Kaupat.sf/sec8da575452a/?ObjectPath=/Shops/Xenon/Products/%22Osram%20D2S%204300K%22
« Last Edit: August 21, 2014, 06:35:23 pm by K9 »
Offline Carpy25
« Reply #23 on: August 21, 2014, 06:37:08 pm »
still cant see how you will power the aftermarket kit from the standard harness sorry to keep chucking in problems but better to sort a way before you start spending money
Rob
Offline K9
  • VW LifeStyle
« Reply #24 on: August 21, 2014, 08:06:29 pm »
or should i hunt for oem ballasters and bulbs?
Offline fazi123
« Reply #25 on: August 21, 2014, 08:09:52 pm »
This is probably the easier and probably cheaper (in the long run) solution.
Offline Carpy25
« Reply #26 on: August 21, 2014, 08:12:47 pm »
temp fix put the kit on your standard headlights lots do this not the best due to the light spread but better than standards then wait until your pickup OEM ballasts and any D2 bulbs will work with them
Rob
Offline K9
  • VW LifeStyle
« Reply #27 on: August 21, 2014, 08:14:43 pm »
do you know the part nr for oem ballasters + d2s bulbs? then only thing i need is the 10 to 12pin adapter right?
i dont need auto-leveling crap :) :P
EDIT: buying them becouse they are oem projector lights from hella and goes for 150£ from a vw worker :)
Offline Carpy25
« Reply #28 on: August 21, 2014, 08:18:39 pm »
no idea of the numbers sorry but don't expect them to be cheap bulbs from VW are silly prices
Rob
Offline K9
  • VW LifeStyle
« Reply #29 on: August 21, 2014, 08:20:57 pm »
but is 150£ cheap for oem hella xenon lights?
