Author Topic: Fitting OEM xenon headlights  (Read 9379 times)
Offline Carpy25
Re: Fitting OEM xenon headlights
« Reply #30 on: August 21, 2014, 08:26:08 pm »
« Last Edit: August 21, 2014, 08:29:08 pm by Carpy25 »
Offline K9
  • VW LifeStyle
« Reply #31 on: August 21, 2014, 08:35:05 pm »
those ballasters are not so expensive at all :) will try to hunt some after i got my headlights home.
so the parts i need is :
2x oem ballasters
2x oem d2s bulbs
2x 10 to 12pin adapter
am i right?
Offline Carpy25
« Reply #32 on: August 21, 2014, 08:46:58 pm »
you will also need the oem harness from the ballasts to the bulbs and after market have ballasts and Igniters combined don't know if oem are separate or not
you may need this as well one each side ?
http://www.ebay.co.uk/itm/AL-BOSCH-OEM-XENON-BULB-IGNITOR-2-PIN-D2S-D2R-Part-no-1-307-329-054-/271098871152?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f1ec07d70
only ever fitter after market and that had one unit with  bulb connected and two wires from same unit that plugged into the halogen bulb connector
how about these bulbs ballasts and wiring harness Plus adaptors ?
http://www.ebay.co.uk/itm/Vw-Golf-Mk5-Xenon-Headlights-R32-Gti-Edition-30-/261570048909?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3ce6ca338d
could work out cheaper as you can sell bits you don't need
Rob
Offline K9
  • VW LifeStyle
« Reply #33 on: August 21, 2014, 08:56:47 pm »
looks good, if buying them, do i have to add something?
Offline Carpy25
« Reply #34 on: August 21, 2014, 09:09:51 pm »
those are damaged you can buy repair kits for the brackets but is the lens is gone that's a problem
Rob
Offline K9
  • VW LifeStyle
« Reply #35 on: August 21, 2014, 09:25:07 pm »
do you know someone else whos selling a complete set?
Offline Carpy25
« Reply #36 on: August 21, 2014, 09:36:20 pm »
I just searched Golf xenons on eBay , just keep checking but I think buying a complete set will work out cheaper in the end  :happy2:
Rob
Offline K9
  • VW LifeStyle
« Reply #37 on: August 21, 2014, 09:39:45 pm »
Rob
thanks you! please tell me if you know someone or find on ebay :)?
offtopic: aux port for my rcd300, where can i find one that sells from uk? want the one that goes beside the esp button :P
