Author Topic: RCD 310 - works with MSFW/Highline Display?  (Read 1280 times)
Offline toms85
« on: August 20, 2014, 10:47:16 pm »
Hi all,
Does anyone know if a RCD 310 DAB work OK with a MSFW and Highline Display on a MY07 GTI? I know I will need a newer Canbus gateway to prevent battery issues.
Thanks  :smiley:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: RCD 310 - works with MSFW/Highline Display?
« Reply #1 on: August 20, 2014, 10:57:43 pm »
yes, although it will depend on which version you buy.
some don't allow the BAP setting to be switched
If you need a Gateway, send me a PM
Cluster and Key coding
Location Great Yarmouth
Offline toms85
« Reply #2 on: August 20, 2014, 11:03:31 pm »
Thanks. What's the BAP setting? The unit I'm getting is from a 2009 MK6.
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #3 on: August 28, 2014, 12:25:54 pm »
It works perfectly with the MFSW and the highline display, it's just a CAN Gateway coding issue.
Most likely you'll need to deactivate the BAP protocol for them to work. I needed to do that on my MY09 Golf, but fortunately my CAN Gateway is compatible so I didn't need to get a new one.
Offline toms85
« Reply #4 on: August 28, 2014, 12:37:02 pm »
Thanks.
I've got a replacement gateway on its way from a 2010 vehicle and will get that coded before I install the RCD310.
« Last Edit: August 28, 2014, 12:44:06 pm by toms85 »
Offline toms85
« Reply #5 on: September 03, 2014, 08:32:21 pm »
Pleased to report the RCD310 worked without needing to do anything - presumably because it was from a 2009 car without a white display and no BAP
