Author Topic: Side skirts (5 door)  (Read 1430 times)
Offline JaseGti
    • Remoteclothing
« on: August 21, 2014, 05:45:48 pm »
On the GTI's are the side skirts just screwed on???
I've found all the screws just hoping if I undo them will they just pop off??
Jase
CW is the way forwards
Remoteclothing.com
Offline Matto
  • -Receive: 116
Re: Side skirts (5 door)
« Reply #1 on: August 21, 2014, 06:02:56 pm »
Unfortunately not no. There is a double sided sticky strip that runs the full length of the skirt. You could use the same method I use to remove badges which is to tie fishing line between two screwdrivers and then use this like a cheese wire to cut through the sticky back foam. There is a chance it will leave some residue so make sure you have some tar/glue remover to hand. Probably be best with 2 people aswell.
Offline JaseGti
    • Remoteclothing
« Reply #2 on: August 21, 2014, 08:58:07 pm »
Cheers for your help bro
Remoteclothing.com
Offline JimmyC92
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,88339.msg896687.html#msg896687
« Reply #3 on: October 19, 2014, 09:19:30 am »
Any chance your looking to sell those?
Looking for some BBS CH/LM Reps to swap for my Classix plus cash your way:
http://www.mk5golfgti.co.uk/forum/index.php/topic,91888.msg924311.html#msg924311
