Author Topic: Help! Back door won't lock  (Read 5134 times)
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« on: August 22, 2014, 03:26:32 pm »
My rear driver side door won't lock.
When I press the lock button I can hear the lock making a double click as if it's locking and then immediately opening!!
Can I manually lock back door?
Anybody ever have this happen?
Offline doylebros
Re: Help! Back door won't lock
« Reply #1 on: August 22, 2014, 05:08:22 pm »
Yes! Give the door a few bangs carefully whilst operating the remote for opening and closing,If it opens follow bellow but remember not to re-rock the car - if it's doesn't it's a lot more high risk, although quite often it does open.
First move get it scanned with VCDS, it will show the fault - test it in output testes for the module number in question.
99% of the time it's the door lock module - cheapest place to get one I found is here
http://www.ebay.co.uk/itm/231105716598?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
He's £110 cheaper than the dealer and the item is new!
You will have to check the part number for a rear module off his shop!
The job at first seems difficult but it you give yourself a chance - take a few photos etc it's pretty simple really!
The trick is to remember to follow the guide above and not loose the T20 for the handle to far.
« Last Edit: August 22, 2014, 05:33:39 pm by doylebros »
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #2 on: August 22, 2014, 05:43:17 pm »
Very thorough and much appreciated!!
A well deserved thank you.
While I was waiting for a reply I took off entire outer leaf and lock module.
It was caked in grease. Removed with degreaser and relubed.
Put all bake together and it works perfect!!
Offline doylebros
« Reply #3 on: August 22, 2014, 05:49:58 pm »
It will most likely be ok for a few weeks then it will fail again - I've opened a few up and it's either PCB Connections or the plastic drive internally is worn and cause the deadlock to stay engaged!
Pleased you've got it open :happy2:
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #4 on: August 28, 2014, 07:09:21 pm »
You were right! Door lock failed again!
You say you've purchased from the ebay lads before?
I think I'll get one now
Offline doylebros
« Reply #5 on: August 28, 2014, 07:18:17 pm »
Found the supplier first class - have even had a unit which went faulty - they changed it without any hassle!
