Author Topic: Enhancing the stock exhaust sound  (Read 5493 times)
Offline Bennz
« on: August 24, 2014, 12:48:07 am »
Just was thinking if there is a way to make the stock exhaust sounds a bit more deeper and louder (not raspy) on the GTI?
Offline Chris92
  • -Given: 33
Re: Enhancing the stock exhaust sound
« Reply #1 on: August 24, 2014, 01:41:08 am »
Remove the pre cat
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
« Reply #2 on: August 24, 2014, 01:49:10 am »
Remove the pre cat. Possibly a DIY job for you to do if you have axle stands but i think i'd rather take it to a garage.. Use the search function to find out more.
After that, i would say its time to move onto replacing your stock exhaust with a 3" downpipe as the standard down pipe is what restricts the cars performance as well as the 400 cell cat which is then replaced with a high flow 200 cell sports cat.
A 3" downpipe coupled with a 200 cell sports cat is what you want if your after extra noise and performance in my opinion. Then at a later date you can save for the cat back to match your downpipe and sports cat.
Also if you do opt for a new downpipe and sports cat.. you may want to think about being able to afford remapping your car too as it will no doubt throw up a cell warning light on your dash if you didn't due to the difference in air flow and other magics happening cause of the new downpipe and cat.
Offline cloud11
« Reply #3 on: August 24, 2014, 01:52:25 am »
Remove the resonator! (this will increase rasp)
OR
or cut the resonator in half, and weld in place a solid pipe inside in place of the original. and drill a few holes (less then the very perforated pipe inside there already) weld it back up and you will get a deeper sound without increasing the rasp, an M3 guy I know have done this and his car sounds better than it did before, and for the £20 it cost him, not bad!
OR a new downpipe with stock catback combined with the above method! Would sound quite nice I think! :signLOL:
these are the cheapest ways to get a nicer sounding exhaust without shelling out alot of cash (downpipe will give more power with map to)
« Last Edit: August 24, 2014, 01:54:55 am by cloud11 »
Offline Bennz
« Reply #4 on: August 24, 2014, 06:02:49 am »
Thanks guys I will look I to the pros and cons of removing pre-cat and the other suggested ways :)
Offline mvb12
  • -Receive: 64
« Reply #5 on: August 24, 2014, 08:04:31 am »
Removing the res section sounds to raspy imo
Offline Bennz
« Reply #6 on: August 24, 2014, 08:18:07 am »
I am not looking for raspy sound. So I won't be removing it.
Would replacing downpipe solve the the pre-cat removing issue? What downpipe is recommended (currently car is not modded but might look I to stage 1 APR or bluefin later on)?
Offline greygti
« Reply #7 on: August 24, 2014, 11:00:24 am »
Get either a 3" BCS, jetex or pipeworx down pipe there all top quality and a good design
Offline Bennz
« Reply #8 on: August 24, 2014, 11:24:32 am »
Maybe I look to see how much work vs benefit vs cost involved in removing pre-cat first , initially didn't want to spend much or change major parts of exhaust as such . Few twirls to enhance the sound :)
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #9 on: August 24, 2014, 11:37:07 am »
http://www.mk5golfgti.co.uk/forum/index.php?topic=41083.0
Offline Bennz
« Reply #10 on: August 29, 2014, 01:17:21 am »
Could someone who had removed the pre cat on their stock exhaust tell me how much extra noise is there in the cabin now ? Thanks
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #11 on: August 29, 2014, 11:01:25 am »
Very little. The exhaust note is a little deeper though  :happy2:
Offline Bennz
« Reply #12 on: August 29, 2014, 12:00:19 pm »
Oh that is good to hear :) was thinking about this but was concerned there will be too much noise in the cabin . I would like the deeper exhaust tone but not raspy
Offline Tweedie
« Reply #13 on: August 29, 2014, 02:49:57 pm »
I have a brand new down pipe and sports cat for sale if your interested. Would be better sound and performance than removing pre cat.
Offline Bennz
« Reply #14 on: August 29, 2014, 11:05:08 pm »
Thanks but I'm not in UK :( across the world in NZ )
