Author Topic: Inner cv boot  (Read 1195 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=jadjgttrvnvd2lhuahoi0g14i2&/topic,90967.msg917089.html#msg917089
Inner cv boot
« on: August 28, 2014, 01:41:08 pm »
Am i correct in thinking the inner CV boot is not as much as of a PITA as the outers.
I've recently replaced both outer CV boots now i've noticed one inner is split. I knew i should have replaced the inners at the same time.
Getting the axle out was not the problem getting the joint off the axle was.
05 | Tornado Red | DSG
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Inner cv boot
« Reply #1 on: September 01, 2014, 12:38:37 pm »
Went to get the parts to change the inner CV boot. Last time i replaced the 6 bolts holding the shaft to the gearbox as i was told they were one use stretch bolts.
I asked the stealers and they said they were not one use. I will be changing the main bolt as i know for sure this is a stretch bolt.
Any one know if the stealers are correct?
Offline xjay1337
  • -Receive: 377
Re: Inner cv boot
« Reply #2 on: September 01, 2014, 12:47:33 pm »
Have re-used the inner CV bolts on my old car loads of times with no issues.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Inner cv boot
« Reply #3 on: September 01, 2014, 01:05:45 pm »
Thanks mate. I will reuse them.
