Author Topic: Fault code help  (Read 1767 times)
Offline Alasdair
Fault code help
« on: August 29, 2014, 10:46:32 am »
Hi Guys, cars just had a service and reading the faults which it has but im struggling to find any guidance on ross tech;
 Fault memory entry
  Number:
 :  VAG00322Switch for deactivation of interior monitoring
   Error type 1:
 Implausible signal
   Error type 2:
 Intermittent
   - Standard ambient conditions:
     Date:
 00:00:00 - 00.00.2000
    Time:
    Mileage (DTC):
 -1
     Priority:
 4
    Frequency counter:
 8
    Unlearning counter / driving cycle:
 225
  Fault memory entry
  Number:
 :  VAG00324Button for deactivation of vehicle inclination sensor
   Error type 1:
 Implausible signal
  Error type 2:
 Intermittent
     Date:
     Time:
    Mileage (DTC):
 -1
     Priority:
 4
     Frequency counter:
 8
 225
Can anyone shed any light on this please?
thanks!
Re: Fault code help
« Reply #1 on: August 30, 2014, 11:00:11 am »
This isn't going to be helpful but I have no idea what's the problem.
I suggest you find someone with a vcds cable from this list and get a proper scan done.
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.msg812454.html#msg812454
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=6c7tndmu8v4bm71mnaml0qped3&/topic,90967.msg917089.html#msg917089
Re: Fault code help
« Reply #2 on: August 30, 2014, 11:20:33 am »
Check that the buttons for disabling the interior alarm sensor and tilt sensor are lit up maybe they are not connected properly.
05 | Tornado Red | DSG
Offline Alasdair
Re: Fault code help
« Reply #3 on: August 31, 2014, 06:51:19 am »
I've never ever noticed that there before I haven't got a tilt one seems strange only interior monitoring which I pressed and it did light up will have to check the faults tomorrow
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
Re: Fault code help
« Reply #4 on: August 31, 2014, 09:13:46 am »
It does not light up when you press it. It lights up with the interior lights. Have you recently updated your Can-Gateway?
I didn't know is was there until my kids stated messing about with it.
