Author Topic: Fitting BBS VZ wheels problem  (Read 755 times)
Offline Black9
  • -Given: 35
« on: August 30, 2014, 03:41:03 pm »
Tried fitting the VZ's today and when I'm putting the stock wheel bolts on they weren't going in far enough to secure the wheel... The stock Monzas go on fine but the VZ's won't?? Any ideas
Offline Leonpettit
  • 2008 Edition 30 DSG - No.1706
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,89470.msg905534.html#msg905534
Re:
« Reply #1 on: August 30, 2014, 03:42:56 pm »
They should be exactly the same. There designed to fit exactly as the monzas do. Check how far they go though the alloy and compare when the wheels are off the car. Will be easier to see then.
Mods coming soon...
Offline Black9
  • -Given: 35
Re: Fitting BBS VZ wheels problem
« Reply #2 on: August 30, 2014, 03:52:59 pm »
Totally confused why they won't go on! I'll remove the wheels again later and have a look
Offline rosco07
« Reply #3 on: August 31, 2014, 11:15:59 am »
Aftermarket wheels usually require aftermarket bolts.  Were you supplied with new bolts?
They are usually tapered rather than radius bolts and usually longer to ensure enough thread goes into the hub.
loads of info on this for example http://www.taperpro.co.uk/2012/bolts.htm
Offline Black9
  • -Given: 35
« Reply #4 on: August 31, 2014, 07:35:23 pm »
As mentioned above the VZ wheels are meant to be designed to be straight fit! The exact same wheels were fitted before but removed as 2 got bucked and were sent away to get a new set. When fitted previously the wheels went on fine albeit they were fitted with a gun...
When I'm fitting them now I'm doing it with a ratchet and when I'm putting them on the bolts feel almost fully tightened but the wheel still has slack and isn't secure at all...
I don't want to over tighten the bolts incase I cause the thread to strip etc...
Offline Black9
  • -Given: 35
« Reply #5 on: August 31, 2014, 10:02:17 pm »
Fitted all 4 wheels tonight and got a new set of problems  :sad1:
When rolling at slow speeds, at points when the front wheels are rotating I can hear a squeaking noise coming from the front of the car. Almost like rubber to rubber contact. Got no ideas what's causing this?
From the rear of the car I can hear a knocking noise also. Every few seconds, not consistent...
The car doesn't make any of these noises when it's running the stock 18" Monzas
The VZ's are running stock 225/40/18 PS3's all round
I have no idea what's causing these issues and I'm at the point of cracking up  :sad1:
Offline Black9
  • -Given: 35
« Reply #6 on: August 31, 2014, 10:05:10 pm »
Another thing,
When the knockings coming from the rear and I put my hand on the handbrake I can feel some sort of friction being causing from the rear wheels
