Author Topic: DSG map  (Read 8428 times)
Offline K9
  • VW LifeStyle
DSG map
« on: August 31, 2014, 01:03:40 pm »
i'm new to dsg golf mk5 gti and heard that u can map the gearbox when you mapping the ecu. what does the dsg map do etc? will the box BOOm  :fighting: faster?
reviews?
Offline Little_Dave
Re: DSG map
« Reply #1 on: September 11, 2014, 08:14:22 pm »
Dsg map does a lot of little things mainly -
Raises gear change rev limit slightly
Raises launch revs from 2.5k to 4k
Raises the rev limiter to 7k I think
Speeds up gear changes
Increases clamping forces
I'm looking to get mine done soon so will post up a review if nobody else has by then  :happy2:
Dave
Offline SRC
  • -Receive: 27
Re: DSG map
« Reply #2 on: September 12, 2014, 08:32:21 am »
I'm tempted by this (though I've done nothing about it yet).
The key feature for me is disabling the automatic upshift when it hits the limiter in manual mode.  If that was removed then it wouldn't upshift at the same time that I do.  Then I'd get the one shift instead of two.
I'd pay £100-150 for that, but I think it's more.
Shadow blue DSG 5 door with leather, sunroof, 18" Monzas, MFSW.
Full list of mods:  Seat inserts and a VW bottle opener.  Each worth 20bhp.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: DSG map
« Reply #3 on: September 12, 2014, 12:37:17 pm »
May not be more than that with another tuner  :innocent:
Offline SRC
  • -Receive: 27
Re: DSG map
« Reply #4 on: September 13, 2014, 08:19:23 am »
Tell me more...
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: DSG map
« Reply #5 on: September 13, 2014, 01:19:15 pm »
Tell me more...
According to this thread: http://www.mk5golfgti.co.uk/forum/index.php?topic=49310.0
A basic DSG map @ R-Tech is £100, although that was 2 years ago so it may be more now. A custom DSG remap is £200
You will probably be tempted to get your ECU remapped too though  :signLOL:
Offline K9
  • VW LifeStyle
Re: DSG map
« Reply #6 on: September 14, 2014, 09:31:00 pm »
is the dsg worth if maping with revo stage 1?
Offline jdm
    • GTINI
  • My Ride: Mk2 Jetta GTI 16V
Re: DSG map
« Reply #7 on: October 19, 2014, 08:56:33 pm »
Had this done on my R32 and can highly recommend it made the car far more driveable, difference was night and day. Quicker changes in all modes and revy.
Offline phas3r
Re: DSG map
« Reply #8 on: November 24, 2014, 05:19:45 am »
Am contemplating on dsg map since there is a sale.
After getting my revo map in 2012, there are a few things that are bugging me
- the shift point is way too early unless my throttle input is more than 50%
- jerky shifts at mid throttle/mid rpm occasionally
Will the dsg map fix the above? I dont need higher rpm limit as my k03 is rather flat at the range.
Also, is it possible to change back to stock dsg map?
And what happens if i reflash back to stock ecu map but my dsg map is still there?
08 MKV GTI DSG shadow blue
Engine: Revo Stage 2 7-3-9 | Forge Twintake | S3 Intercooler | R8 Coils | APR RSC MK6 Catback + 3" DeCat Downpipe
Brake/Susp : Golf R 345mm Front | Michelin PS4 225/40/18 | BBS CO VZ033 18" | H&R Rear ARB | S3 Lower Arm Bush
Interior: RNS 510 | 9WZ | Retrofitted CC | MK6R Rev Cam | Midline cluster :(
Offline bigeyd
  • -Receive: 31
Re: DSG map
« Reply #9 on: November 24, 2014, 06:27:16 am »
In sport mine is jerky in the lower gears,I have a K04 so a bit more power.
The DSG map is good but now I'm at stage 2+ I see a stage two DSG map is available,I have more than enough power so I will stick to the one I have
Offline chris s
Re: DSG map
« Reply #10 on: November 24, 2014, 07:08:00 am »
Does anyone know if it's still possible to cruise around town or on the motorway without revving the tits off your car with a DSG remap?
Candy White Edition 30 DSG
Revo Stage 2+
ITG, BCS TBE, Autotech HPFP
WALK
R32 Brake upgrade
S3 IC upgrade
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=0cpfgu87ase4moraoijf68qcna&/topic,19740.0.html
Re: DSG map
« Reply #11 on: November 24, 2014, 09:12:31 am »
Yes you can..... If you couldn't it would be a bit sh*t.
Offline GS WAX
Re: DSG map
« Reply #12 on: November 24, 2014, 06:43:55 pm »
I presume he means in S mode, if so no you cant.
P.s  anyone with cruise control,make sure you have the revised file,if it is the same as mk6 then cruise is not working properly.
pps  DSG map is not 100% satisfactory if you specify linear throttle,according to tech at revo, I tried it first and it was terrible for general driving.
Offline chris s
Re: DSG map
« Reply #13 on: November 24, 2014, 08:58:18 pm »
Thanks for clearing that up Rich
Revo Stage 2+
WALK
R32 Brake upgrade
S3 IC upgrade
Re: DSG map
« Reply #14 on: November 24, 2014, 09:02:50 pm »
Why would you drive around town or down a motorway in S mode?
