Author Topic: Fitting turbo back down pipe and exhaust? Anything I need?  (Read 1309 times)
Offline arris
« on: September 02, 2014, 08:35:53 am »
Right bought a turbo back down pipe and exhaust that I'm looking at fitting at weekend.
Is there any gaskets or bolts I should buy to replace at same time?
If so what ones or part numbers so I can order from TPS to have on the day.
Any other tips would be nice also :)
Rick
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=5r61vs69ktbv2lp2qjqjtsjv4t&/topic,19740.0.html
Re: Fitting turbo back down pipe and exhaust? Anything I need?
« Reply #1 on: September 02, 2014, 09:33:05 am »
Change the exhaust/turbo gasket for sure. I think thats good practice. Bolts should be ok to reuse
Offline arris
« Reply #2 on: September 02, 2014, 09:51:49 am »
I thought that maybe the case.
I'll try get down TPS and order one  :happy2:
« Reply #3 on: September 02, 2014, 10:01:15 am »
Alex uses high temp silicone on the joints of the exhaust too... so I would do that so it seals better and makes any later adjustments/removal easier.
Offline Spankiee
  • -Receive: 20
« Reply #4 on: September 02, 2014, 10:13:09 am »
Anyone recommend which silicone to buy?
candy white edition 30
« Reply #5 on: September 02, 2014, 10:16:18 am »
Google it. Black high temp silicone gasket. Loads to choose from.
