Author Topic: Oil pickup pipe  (Read 2343 times)
Offline Airz182
Oil pickup pipe
« on: September 02, 2014, 10:14:24 pm »
Recently my oil preassure light has come on and the warning message telling me to switch of engine, stripped the sump off it tonight and the pick up pipe, to find the pick up pipe clogged up again?? I changed this pipe 4-5months ago, i wouldnt of thought it would be so clogged so quickly?
It was clogged with what only i can described as small soot/carbon peices
There was no metal fragment at all in there. I come
Pick up the little pieces and rub them together and it just turned to like a charcoal dust.
Any ideal of what this is from?
Instagram- airz182
dansmith180
Re: Oil pickup pipe
« Reply #1 on: September 02, 2014, 10:23:02 pm »
Sorry to ask you a question instead of answering yours, I need to do mine and I have a pick up pipe, medium O ring and the sealant is that all I need? It looks like there's gasket or something but TPS were no help and I can't find any mention  of one on any threads.
  • -Receive: 453
Re: Oil pickup pipe
« Reply #2 on: September 02, 2014, 10:24:46 pm »
What oil are you using?
Offline th3_f15t
  • -Receive: 183
Re: Oil pickup pipe
« Reply #3 on: September 02, 2014, 10:25:21 pm »
Message Xjay, the admin. He did write a guide on here I believe...
Offline Airz182
Re: Oil pickup pipe
« Reply #4 on: September 02, 2014, 10:27:39 pm »
Yeah thats all, apart from the obvious tools
Torqs bits, 10mm socket and extension.
5mm (i think) ball headed allen key
Theres 3bolts from the gear box to the sump, allen key for them
Somebody else may chirp in if i forgot anything!
Ive used tfr to clean my sump out.
Instagram- airz182
dansmith180
Re: Oil pickup pipe
« Reply #5 on: September 02, 2014, 10:29:01 pm »
Offline Airz182
Re: Oil pickup pipe
« Reply #6 on: September 02, 2014, 10:29:34 pm »
Tbh i cannot remeber what i put in it! I remeber searching to see what was better put in but cannot rember what i end up buying
Instagram- airz182
Offline th3_f15t
  • -Receive: 183
Re: Oil pickup pipe
« Reply #7 on: September 02, 2014, 10:32:20 pm »
