Author Topic: Polar FIS+ or Fiscon E-MFA Add-On  (Read 7014 times)
Offline rex
  • -Given: 50
  • -Receive: 74
« on: September 03, 2014, 06:50:55 am »
Hello,
I am after my next interior mod for my MY 2008 GOLF GTSport and I have to choose between:
Polar FIS+ which costs 250 EURO / 200 GBP
Fiscon E-MFA Add-On which costs 150 EURO / 120 GBP
I have done some reading and I can't really find answers to some of my questions... So any help is much appreciated!
I originally had a 'comfortline' instrument cluster (small display) and I changed this with a highline R32 instrument cluster.
My questions are the following:
1. Do you have any of the above products? Are you happy with it?
2. I know that both products work with highline instrument cluster but since I have retrofitted my highline cluster I am not sure if I need other parts as well. So, will either of them work for with a steering wheel column that does not support multifunction steering wheel?
3. Is the oil temperature reading accurate? Are there any was to see if my car has an oil temperature sensor?
4. Do you access these new menus just like a regular menu (like instant consumption / average consumption / speed warning / etc?) or are these menus accessible only in the menu where you make configuration mods (like auto close the doors, coming/leaving home, etc?). Is the access the same for both Polar and Fiscon (except for the fact that Fiscon uses the radio menu)?
Thank you for your help  :notworthy: .
Offline Viking
  • -Given: 17
  • -Receive: 47
Re: Polar FIS+ or Fiscon E-MFA Add-On
« Reply #1 on: September 03, 2014, 07:53:04 am »
Throw a bit more cash at it and get the Fiscon Bluetooth with E-MFA add on included. This is mine.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #2 on: September 03, 2014, 02:56:53 pm »
Thanks for the idea!
I don't really need the bluetooth so I guess it's not worth the money for me.
Did you have the highline instruments cluster as stock or did you buy the cluster at a later point?
Do you have multifunction steering wheel?
« Reply #3 on: September 03, 2014, 04:34:30 pm »
My first question is can you scroll through the different menus (audio, settings etc) in the mfd display at present?
If you can't then the polar is not for you.
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #4 on: September 04, 2014, 06:33:19 am »
No, I can't access those menus.  :sad1: Do I need a Highline Steering Wheel Column Computer to be able to do that?
All I can do is to scroll through instant consumption, average consumption, range, speed warning, etc...
I have this instrument cluster:
So I guess it's not going to work for me?  :sad1:
« Last Edit: September 04, 2014, 07:17:53 am by rex »
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #5 on: September 04, 2014, 08:06:49 am »
I have MFSW and Highline as standard mate.
Bluetooth is always worth it mate. Saves the temptation to "just answer this call" and get yourself some points.  :happy2:
Offline Softishman
« Reply #6 on: September 04, 2014, 08:44:49 am »
Where can i buy the Fiscon e-mfa with bluetooth? Link?
Offline arris
« Reply #7 on: September 04, 2014, 08:48:00 am »
Have you thought about the p3 guage?
http://www.p3cars.com
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #8 on: September 04, 2014, 09:07:39 am »
Offline Softishman
« Reply #9 on: September 04, 2014, 11:01:52 am »
But i find one BASIC 249 Euro and BASIC plus 299 Euro... ?!
What´s the difference?  :ashamed:
Offline Jonneh
« Reply #10 on: September 04, 2014, 11:04:22 am »
I take it none of these systems will work with an MFD2 nav then? :(
Passat R36 - Corrado VR6 - Mk2 Golf GTI 8v
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #11 on: September 04, 2014, 11:39:35 am »
Read the description  :booty:
Offline Softishman
« Reply #12 on: September 04, 2014, 12:55:04 pm »
You don't know freddy? :booty:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #13 on: September 04, 2014, 07:23:23 pm »
You might need to upgrade your steering wheel module or the confort module. There are a few members here that can help you with that.
I chose the PolarFIS Adv. because I didn't need a Bluetooth module, I use a Bluetooth headset that can go with me outside the car.
My Golf had the MFA+ with a MFSW as standard, so it was very easy to fit the box above the pedals, connected to the CAN Gateway.
Basically you can get the information that your car's sensors give the ECU, so it's like having a VCDS cable hooked up while driving. It gives a lot of information in real time. I like it. :smiley:
You can get the unit from the Polar Team online shop: http://www.polarteam.net/en/home/65-polar-fis-advanced.html
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #14 on: September 04, 2014, 07:26:45 pm »
You want someone to do all the work for you  :P
Still live with your mum?  :innocent:
