Author Topic: Polar FIS+ or Fiscon E-MFA Add-On  (Read 7008 times)
Offline rex
  • -Given: 50
  • -Receive: 74
Re: Polar FIS+ or Fiscon E-MFA Add-On
« Reply #15 on: September 04, 2014, 08:00:12 pm »
Thanks for your comments and help, guys!
Yup, I've done a lot of reading and it seems I have to change the steering wheel computer for Fiscon or Polar FIS to work.
Now, I am searching to see if 1K0 953  549 AG is ok (I can get this at  27 GBP) or I need a newer model like 1K0 953  549 CH (which I can get at 72 GBP). Any thoughts, anyone ?
« Last Edit: September 07, 2014, 10:26:59 am by rex »
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #17 on: September 04, 2014, 08:41:13 pm »
Cheers  :notworthy:!
Will the CH one work with the Mk5 steering wheel and mk5 cruise control?  :drinking:
*Edit: A steering control module is, at the dealer, around 140 GBP. Are those cheap Chinese replicas?
« Last Edit: September 04, 2014, 09:13:42 pm by rex »
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #18 on: September 04, 2014, 09:52:17 pm »
There genuine Vlad  :happy2:
Will work with the steering wheel fine, but i think you need the latest revision cruise stalk, G or J iirc
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #19 on: September 04, 2014, 11:53:41 pm »
I also have been unable to get my polar fis+ to work, as i have not got a MFSW, would a suitable CH like in the link, fix this...?
Infact i am unable to enter the menu option, except the normal usual MPG, max speed, time traveled etc...
Highend Controller – 1k0 953 549 AQ ?????
As far as i am aware, i need a mfsw to let me enter the extra options, due to the clocks, then my polar fis should work.
Sorry to hijack, but just on the of chance !
Have the usa highline dash, cruise control and the extra menu highline stalk fitted.
mk5 gti
2006
 :notworthy:
« Last Edit: September 05, 2014, 12:11:13 am by scopes »
Silver is the way !
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #20 on: September 05, 2014, 07:02:43 am »
Neil,
Did you code the steering wheel controller properly?
It should work with your car (from what I read)...
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #21 on: September 05, 2014, 09:16:33 am »
Neil,
 :drinking:  Rex matey, I had someone do it for me, so i'm really not too sure...  :ashamed:
How could i tell? if it has or has not been coded correctly?
thanks
Silver is the way !
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #22 on: September 05, 2014, 05:23:22 pm »
Well, I guess the coding has to be according to the new hardware.
From what I read it should work just fine.. Do you know how to access the menu (long press the up button)?
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #23 on: September 05, 2014, 05:37:29 pm »
Yeah matey, but still dosent work, i have tried pushing all the buttomn, even trying some together  :signLOL:
As far as I'm aware its to do with not having a MFSW !
If i remember correctly, TFSI Mike has the same problem !
We have been unlucky...  :fighting:
Silver is the way !
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #24 on: September 05, 2014, 08:36:50 pm »
Well, that's a problem because I also don't have (and I don't plan on having) a MFSW  :sad1:.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #25 on: September 06, 2014, 12:35:20 am »
I have guy with a mk6 mfsw, he is willing to try it,  :smiley:  but would i then need a dfferent controller?
Silver is the way !
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #26 on: September 06, 2014, 12:38:00 am »
You could be lucky enough to have the more suitable clocks...
I think it was something to do with the dash i got, came from a car with a mfsw fitted...
Silver is the way !
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #27 on: September 07, 2014, 06:06:04 pm »
From what I've read, yes you will need a CH controller.
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #28 on: September 07, 2014, 06:16:02 pm »
 :sad1:
I think/hope there is another explanation for that. Check the coding once more, just to be sure...
My clocks come of a 2009 R32. If it was DSG it had MFSW. So I think I should follow FAB5FREDDY' s advice and get a CH controller. My only concern is if they're genuine or not (as I understand they are made in China for the local market and for the USA market.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #29 on: September 07, 2014, 06:41:53 pm »
Next try will be a new Ch controller... With a MFSW !
I also hope my clocks are genuine ones, as my dash is USA spec !  :rolleye:
Silver is the way !
