Author Topic: Intake cleaning by the 'hydrogen method'  (Read 2208 times)
Offline OSB
  • -Given: 32
« on: September 07, 2014, 09:27:34 am »
Some of you may remember this thread from a couple of weeks ago.
http://www.mk5golfgti.co.uk/forum/index.php/topic,47622.45.html
So to keep you up to date...
I accepted the offer of a free clean and subsequently have been in contact with Lee. We have arranged for the process to be carried out next Friday. All seems fine so far.
It's a drive up to Stevenage so I'll have a before and after drive, which, if it has the desired result I should feel.
I should be getting before and after emissions readings too.
I haven't been able to get a 'lookie scope' for visual results yet, but we'll see. ( no pun intended!).
Looking forward to Friday!
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Intake cleaning by the 'hydrogen method'
« Reply #1 on: September 07, 2014, 10:46:28 am »
Keep us informed of the outcome pal  :happy2:
Offline mvb12
  • -Receive: 64
« Reply #2 on: September 07, 2014, 12:28:09 pm »
so I read through the link and I must have missed some info......
whats this company called?
have we got any back to back readings as this Lee stated he has?
Is this a mobile service or do they have a unit?
Offline flashp
  • -Receive: 65
« Reply #3 on: September 07, 2014, 06:45:24 pm »
A camera is the only surefire way to assess effectiveness of cleaning. Dyno readings may show no difference at all (assuming that's what you meant).
I noticed when mine were cleaned manually but it was slight. Ideally this should be considered as an exercise in maintaining efficiency rather than adding power.  :happy2:
Sorry if I'm quoting the obvious.  :wink:
Gone but not forgotten :-)
Offline OSB
  • -Given: 32
« Reply #4 on: September 10, 2014, 05:18:14 pm »
So next stage in the process ...
Took the car to Duncan's in Byfleet (unashamed plug for one of the nicest indie garages around!) for a' pre clean' emissions check today.
Figures for Fast Idle Test were:
CO % Vol        =  0.004
HC ppm vol     = 0
Lambda          = 1.000
Natural Idle  Test
CO % vol       = 0.003
I'll be going back for a comparison as soon as I can after the clean.
I'll post any other findings as soon as I have them ......... :happy2:
Offline flashp
  • -Receive: 65
« Reply #5 on: September 10, 2014, 10:27:06 pm »
I had a manual clean of the valves and a few weeks later I got these figures at the MOT, 42,000 miles on the clock.
FAST IDLE
CO - 0.08%
HC - 16ppm
Lambda - 0.999
NATURAL IDLE
CO - 0.03
Previous MOT @ 36.5k miles and also before stage 2 & stage 2+ upgrade results were:
FAST IDLE
CO - 0.01%
HC - 39PPM
Lambda - 1.002
NATURAL IDLE
CO - 0.01
Not sure that there's much value in these figures as they pre-date extensive tuning work, but here they are all the same.
Just in case it's useful  :happy2: Mine is stage 2+ with an APR pump, in case it makes any difference to anything.
*Corrected Lambda reading and added mileage.
« Last Edit: September 11, 2014, 06:35:36 pm by flashp »
Offline OSB
  • -Given: 32
« Reply #6 on: September 11, 2014, 07:52:22 am »
Thanks flashp.
Did you have a before test for comparison?
Did you notice any difference afterwards - performance, fuel consumption, idle etc?
BTW
Interesting you got 0.030 on the Lambda and passed the MOT - the MOT sheet I have says Min Limit 0.970!
Offline flashp
  • -Receive: 65
« Reply #7 on: September 11, 2014, 08:08:09 am »
I shall double check the Lamda reading this evening in case it's my mistake. It said 'pass' against the test but that part of the print out is quite busy with text.
« Reply #8 on: September 11, 2014, 08:31:00 am »
Just out of interest what mileage are your cars?
Mine just under 30k done in March:
FAST IDLE
CO - 0.00%
HC - 6ppm
Lambda - 1.00
NATURAL IDLE
CO - 0.00
Offline OSB
  • -Given: 32
« Reply #9 on: September 11, 2014, 04:55:37 pm »
FAST IDLE
CO - 0.00%
HC - 6ppm
Lambda - 1.00
NATURAL IDLE
CO - 0.00
Mine has done 66K
Offline Llew
  • -Given: 45
« Reply #10 on: September 18, 2014, 08:24:30 pm »
Any updates on this?
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
