Author Topic: Ed30 knocking sound diagnosis  (Read 1417 times)
Offline ED300888
« on: September 07, 2014, 12:32:40 pm »
I have an annoying knock which seems to be coming from the front end. I have changed the drop links, had the subframe spacer brackets put in, engine front arm front and rear bushes, had all the obvious joints checked and running out of ideas and patience! It does it when pulling off my front when I am on lock and also when coming off acceleration and engine weight transfers and sometimes going over bumps. I am thinking either an engine mount? Done lower so 2 left, rear drop links or arb bushes?
HELP!!! TIA...
Offline ED300888
Re: Ed30 knocking sound diagnosis
« Reply #1 on: September 08, 2014, 12:39:22 pm »
No?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #2 on: September 08, 2014, 12:51:12 pm »
ARB bushes??
When I eventually get a passenger ride, i'll help diagonse it  :innocent:
Offline grumpy
« Reply #3 on: September 13, 2014, 09:59:42 pm »
Hi, have you fixed your knocking noise? Just wondering as I have same. Thank you  :party:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #4 on: September 13, 2014, 10:05:35 pm »
I've text him today, he still hasn't fixed it  :sad1:
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
« Reply #5 on: September 14, 2014, 06:07:51 am »
Mine is also making a knocking noise on the front passenger side, found out today its the engine mount that needs replacing to much play & engine movement causing the knocking noise. But that's just mine worth a check though. :happy2:
Stage 2 MK5 GTI Revo GONE
Stage 1+ MK5 GTI R-Tech GONE
Offline john87
  • -Receive: 53
« Reply #6 on: September 14, 2014, 09:33:41 am »
Possibly unrelated but a friend of mine had a knocking noise from his 06 Corsa when coming off the gas and going over speed bumps.
He had the passenger side track rod-end replaced and the drivers' side ARB bush. Knocks now gone  :happy2:
