Author Topic: Door locks  (Read 1073 times)
Offline Markweir12
Door locks
« on: September 08, 2014, 10:10:34 pm »
Just a quick question.
When I unlock the car, the passenger door stays locked?
This is with pressing button twice?
Am I being thick
Offline kc888
Re: Door locks
« Reply #1 on: September 08, 2014, 10:24:56 pm »
door lock module could be on the way out!
Offline doylebros
Re: Door locks
« Reply #2 on: September 08, 2014, 10:29:42 pm »
Offline AndyBrown
Re: Door locks
« Reply #3 on: September 08, 2014, 10:29:47 pm »
Have you got a highline display? There's an option in there, I can't remember what it's called off the top of my head
Offline Markweir12
Re: Door locks
« Reply #4 on: September 08, 2014, 10:30:37 pm »
Not sure, display shows constant mpg etc
Offline AndyBrown
Re: Door locks
« Reply #5 on: September 09, 2014, 07:51:10 am »
Have you got anything on the washer or indicator stalks to change it?
Multifunction steering wheel?
Offline Markweir12
Re: Door locks
« Reply #6 on: September 09, 2014, 07:54:22 am »
Na just normal steering wheel, nothing on  stalk to suggest ability to change things
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
Re: Door locks
« Reply #7 on: September 09, 2014, 08:41:51 am »
I'd second door lock module on it's way out.
Happened to me a month ago, door lock would fail every other day so I had to get a new one.
I assume you have a 3 door since you only commented on passenger door and not front/rear. Your setting might just be set to open driver door only BUT has this only started happening recently? If so, and you haven't coded it to do so I'm afraid your lock is on the way out.
New one from eBay would be around £40 and from the dealer £110. I took a chance with eBay and fitted last week with no problems.
It's a DIY job but you need a T20, T30 torx and an M6 Spline I believe
Offline Markweir12
Re: Door locks
« Reply #8 on: September 09, 2014, 08:46:49 am »
Thanks guys,
Ye 3dr .. and It happened on off so seems it will be the lock.
Will get one ordered and some tools and report back
