Author Topic: tips on how to unclip accelerator  (Read 1543 times)
Offline wodder42
« on: September 09, 2014, 08:42:03 pm »
Fitting my gti pedals and finding it tricky to unclip the connector and press the grey tab down at the same time.
any one have any tips or instructions?
140 GT, Steel grey, smoothed R32 rear, GTI front with all black US grill, DRL's, ED30 interior, GTI pedal set, 18" Monzas, GTI headlights and R32 rear lights
Offline dajonic
  • -Given: 17
Re: tips on how to unclip accelerator
« Reply #1 on: September 09, 2014, 09:03:20 pm »
If you're changing the whole peddle then the electrical connector on the back is the easy bit just take your time. The actual body of the accelerator however is held on with two hidden clips underneath the base of the pedal which locks onto two metal lugs attached to the footwell floor. You'll need two thin blade long handle screw drivers and three hands. The pedal has a flat base, push the pile of the carpet down with your hands and you'll see two small spaces which you put the screwdrivers into. You have to twist one to the side and push the other straight in but i can't remember which one is which. This basically releases the sprung catches and the pedal should pop off. If you break them a new ones £125 from the dealers.
Ps, there's a third bolt on the side of the pedal to the side of the connector under a little plastic cover.
« Last Edit: September 09, 2014, 09:12:00 pm by dajonic »
Offline wodder42
« Reply #2 on: September 09, 2014, 09:21:09 pm »
Its just the electrical connector that im struggling with...how do you hold the white clip down and pull off the plug?
Offline dajonic
  • -Given: 17
« Reply #3 on: September 09, 2014, 09:25:59 pm »
Don't remember struggling with that to be honest although I think I used a flat blade screwdriver to push down the tab that holds it in place with one hand and pulling the plug out with the other hand. Just awkward getting in there and seeing what you're doing.   :happy2:
Offline wodder42
« Reply #4 on: September 10, 2014, 06:13:03 pm »
Anyone?
