March 31, 2025, 04:25:02 pm
All Things Mk5
Mk5 General Area
Drivers side speaker stop working
Topic: Drivers side speaker stop working (Read 6769 times)
axsweb
Always Involved
-Given: 10
-Receive: 2
September 10, 2014, 04:47:35 pm »
Was driving home and put the window down a little and driver side speaker stop working....no sound...used the fader to confirm this on the stereo. What could be the possible faults?
OSB
Always Involved
-Given: 32
-Receive: 17
Re: Drivers side speaker stop working
Reply #1 on:
September 10, 2014, 07:24:46 pm »
Wiring to speaker has come loose and the window or winder mech has hit it?
th3_f15t
Just look at my post count
-Given: 66
-Receive: 183
My Ride:
Reply #2 on:
September 10, 2014, 07:26:47 pm »
Most likely wiring within the door, or total failure of the speaker itself.
OSB
Always Involved
-Given: 32
-Receive: 17
Reply #3 on:
September 10, 2014, 07:26:58 pm »
You will probably have to get the door trim off and then ascertain whether there is a signal to the speaker and work back on the wiring from there.
DANBOY66
-Given: 41
-Receive: 55
My Ride:
Reply #4 on:
September 10, 2014, 07:42:10 pm »
no help what so ever
but I have speakers and cross overs but no looms for sale will sort you out for beer tokens if you need a speaker or cross over
dan..
Dan..
dan930
-Given: 0
-Receive: 56
Reply #5 on:
September 10, 2014, 08:02:14 pm »
Quote from: th3_f15t on September 10, 2014, 07:26:47 pm
+2
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
v4rley
-Given: 29
-Receive: 104
Reply #6 on:
September 10, 2014, 08:12:30 pm »
I had this issue with my 05 GTI, although it's only a slim chance it maybe the same problem. My speaker wire had worn loose at the connector in the front door jam. If you open the front door the is a rubber boot where the connector is and mine had snapped here, best to check here first as it easier than removing the door card.
This shows my issue...
http://www.myturbodiesel.com/wiki/door-wiring-harness-cracked-wire-replacement-mk5-vw/
axsweb
Always Involved
-Given: 10
-Receive: 2
Reply #7 on:
September 11, 2014, 04:10:53 pm »
Thanks guys...sorted it. It was a loose wire on the speaker
All Things Mk5
Mk5 General Area
