Author Topic: Help please....  (Read 1787 times)
Offline fazi123
Help please....
« on: September 10, 2014, 06:46:57 pm »
Hi Guys,
I got a VAGCOM and have scanned my cars after the ESP and ECP lights have come on. I'd appreciate any pointers as to what it could be.
Wednesday,10,September,2014,18:44:57:27053
VCDS Version: Release 12.12.3 (x64)
                Address 01: Engine       Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 1K0 907 115 J    HW: 8P0 907 115 B
  Component and/or Version: 2.0l R4/4V TFSI     0030
           Software Coding: 0403000318070160
            Work Shop Code: WSC 00248 210 83408
                      VCID: 2D576E58B478937600B-8078
3 Faults Found:
000545 - Angle Sensor 2 for Throttle (G188)
               P0221 - 008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 0
                    Fault Frequency: 3
                    Reset counter: 255
                    Mileage: 105653 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:18:58
             Freeze Frame:
                    RPM: 1013 /min
                    Load: 48.2 %
                    Speed: 37.0 km/h
                    Temperature: 85.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.716 V
005476 - Throttle Actuator (J338)
               P1564 - 002 - Under-Voltage during Basic Setting - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 105677 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 21:38:14
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 18.0°C
                    Temperature: 18.0°C
                    Voltage: 11.430 V
000289 - Throttle Position Sensor (G69)
               P0121 - 008 - Implausible Signal
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 105699 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:03:28
             Freeze Frame:
                    RPM: 2697 /min
                    Load: 63.5 %
                    Speed: 38.0 km/h
                    Temperature: 84.0°C
                    Temperature: 30.0°C
                    Voltage: 13.843 V
Readiness: 0000 0000
Thanks,
Faz
Re: Help please....
« Reply #1 on: September 10, 2014, 07:14:07 pm »
You need a new throttle body...    :sad1:
Offline fazi123
Re: Help please....
« Reply #2 on: September 10, 2014, 10:10:43 pm »
Noooooooooooo! Thats exactly what I did not want to hear :( :(
