November 16, 2024, 07:56:46 am
All Things Mk5
Sat Nav and Car Audio
Rns510 connecting to highline (mfd)
Topic: Rns510 connecting to highline (mfd) (Read 6889 times)
Callumed30
Always Involved
-Given: 1
-Receive: 0
September 13, 2014, 10:32:33 am »
Hi new to forum so was hoping someone could point me in right direction.
Recently bought a ed30 gti, it has the rns 510 sat nav unit but nothing appears on my highline ive tried having the car coded by vw and a specialist but cant seem to connect them up using vagcom.
After doing some digging around on net i can only put it down to my can gateway being out of date, ive read about battery drain also and since buying car i have had the battery replaced but i have left the car for 3 days before and has started up fine so dont think im getting that. I'll be taking car back to specialist on thursday so will get can gateway part no.
If someone could point me in right direction that would be great cheers!
RetroRaz
Just look at my post count
-Given: 32
-Receive: 194
Re: Rns510 connecting to highline (mfd)
Reply #1 on:
September 13, 2014, 10:35:25 am »
when you press and hold the buttons on the wiper stalk does the menu come up? it should say nav, audio, etc
#RetroRaz -
https://instagram.com/retroraz/
Callumed30
Always Involved
-Given: 1
-Receive: 0
Reply #2 on:
September 13, 2014, 12:03:51 pm »
Ye menu but all i get is MFD and setup its not connected to highline and have tried vagcom coding but nothing works
Viking
Won't Shut up.
-Given: 17
-Receive: 47
Reply #3 on:
September 13, 2014, 12:26:53 pm »
Have you told the RNS unit to talk to the Highline display? Specifically, I would look at navigation, byte 7, bit 7, and untick BAP.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Callumed30
Always Involved
-Given: 1
-Receive: 0
Reply #4 on:
September 13, 2014, 12:31:25 pm »
I was jus told by chris at vw midland he had done everything ill spk to him thursday an see if this helps thanks!
Viking
Won't Shut up.
-Given: 17
-Receive: 47
Reply #5 on:
September 13, 2014, 12:51:21 pm »
Don't forget to reboot the RNS unit when finished. All three buttons at the same time [Left Arrow < Right Arrow > and Star button. In fact you could try that right now just in case it's been forgotten.
bacillus
-Given: 4
-Receive: 451
Reply #6 on:
September 13, 2014, 01:32:50 pm »
Quote from: Callumed30 on September 13, 2014, 10:32:33 am
Well I'm using a F revision gateway with my 510 and have no issue with mfd display including compass so that not your problem.
Shoduchi
-Given: 220
-Receive: 429
My Ride:
Reply #7 on:
September 13, 2014, 03:42:47 pm »
The only coding needed for the cluster to work is just turning off the BAP protocol. Then, as said before, reboot the RNS-510.
To finish the coding you just need to add Navigation in the Gateway installation list and code the RNS-510 according to your car's hardware in the Long Coding Helper, that is pretty simple to use with some tips from online DIY.
Silver Reflex Mk5 Golf GT Sport
.:R-Line
1.9 TDI 105@171PS 5 Doors
Candy White Mk5 Golf GTI Edition 30 DSG 230@409PS 3 Doors
Callumed30
Always Involved
-Given: 1
-Receive: 0
Reply #8 on:
September 13, 2014, 03:45:57 pm »
Ive rebooted it but still nothing, ive spoken 2 chris he will do what Viking suggests if not ill look at can gateway part no an see if it needs to be revised. Cheers
Shoduchi
-Given: 220
-Receive: 429
My Ride:
Reply #9 on:
September 13, 2014, 03:53:21 pm »
If your Golf is not from 2008 most likely your CAN needs to be upgraded if you wish to install the newer firmwares available. The older firmwares don't drain the battery but they don't have the new functions and screen layouts.
There's also a firmware fix that works on some RNS-510 to avoid the need for a CAN upgrade.
Last Edit: September 13, 2014, 03:55:19 pm by Shoduchi
.:R-Line
Callumed30
Always Involved
-Given: 1
-Receive: 0
Reply #10 on:
September 13, 2014, 06:49:07 pm »
Mines a 07reg and I'm guessing the guy who put it in just did the unit and coded as much as possible without too much knowledge, so I'm guessing ill need to upgrade the can gateway then?
Shoduchi
-Given: 220
-Receive: 429
My Ride:
Reply #11 on:
September 13, 2014, 07:08:30 pm »
You can check the part number of your CAN gateway by looking at it under the dash or by using a VCDS cable.
Here's a DIY for retrofitting a RNS-510 that shows how you can replace your CAN:
http://www.myturbodiesel.com/wiki/rns510-rns315-gps-or-rcd510-installation-in-a-mk5-vw/
My car is from Nov/2008 and has a CAN with the part number 1K0 907 530 Q, so I was lucky to not need to upgrade it.
Here you can check from the list which CAN are compatible:
http://wiki.ross-tech.com/wiki/index.php/Navigation_System_(RNS510)_Retrofitting
I advise to upgrade if yours isn't compatible. You'll have more peace of mind about the battery draining issue.
.:R-Line
Viking
Won't Shut up.
-Given: 17
-Receive: 47
Reply #12 on:
September 13, 2014, 07:16:41 pm »
None of which should have any bearing on the RNS unit communicating with the Highline display. The CAN gateway will cause the battery drain issue perhaps, but that isn't a problem right now.
Shoduchi
-Given: 220
-Receive: 429
My Ride:
Reply #13 on:
September 13, 2014, 07:30:10 pm »
Yeap, as I said before, the only coding needed for the cluster to work is just turning off the BAP protocol.
.:R-Line
Eddie-NL
Trader - 2014
-Given: 0
-Receive: 298
My Ride:
Reply #14 on:
September 14, 2014, 10:47:20 am »
also worth checking the firmware
Some modified firmware can cause no communication with the highline, even if all is coded correctly
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
All Things Mk5
