Author Topic: Dans grey MK5 GTI. Prepping for VagTuner  (Read 291424 times)
Offline Gti_Mad
Re: Dans grey MK5 GTI - soon to be BWJ powered - car at AKS
« Reply #660 on: May 16, 2016, 09:00:15 pm »
Couldn't stop staring at that charged 32 yesterday........ Any idea wot power it's running ??
dansmith180
« Reply #661 on: May 16, 2016, 09:11:56 pm »
Yeah me too, I'm quite taken with it. I believe its somewhere around 390bhp
Offline TAPPY
  • -Receive: 56
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,103290.0.html
« Reply #662 on: May 16, 2016, 10:12:29 pm »
@TAPPY oh nice one I'd forgotten about Stoner, I should be picking my car up on the 4th so will hopefully bring it down. Most likely we will all go and bring a couple of the cars between us.
I only got reminded today. Just checked the dates and it's 2 days before my holiday so I should be going. Hopefully see you there and see all the good work you have had done :happy2:
Cheers mate  :love:
I'll drop you a PM a few days before if I am going  :happy2:
Yeah perfect buddy
Offline jasam
  • My Ride: 2.0 tfsi k04, revo stage 3
Re: Dans grey MK5 GTI hybrid k03. made a whoopsie
« Reply #663 on: May 18, 2016, 08:22:28 pm »
So after the spark plug issue and suspected under fuelling I changed the fuel filter and upgraded the LPFP to one of these
http://www.awesomegti.com/car/vw/golfmk5/deatschwerks-dw65v-high-flow-fuel-pump-90769
Then yesterday she went on the dyno for testing to log all parameters and see if anything is wrong.
Was that pump straight fit? Or needs some job, trimming something, new clamps, or anything.. ?
dansmith180
« Reply #664 on: May 19, 2016, 08:18:47 am »
I didn't do it myself I had a mechanic do it, all the reviews and he said it was pretty straight forward though. You just pull out the old pump and put the new pump into the original housing/ basket, takes a little while but is pretty easy and as far as I know everything is provided.
dansmith180
« Reply #665 on: May 27, 2016, 11:18:38 pm »
Some things are going on
As you can see it was pretty damn filthy in there, also it was quite gunky instead of the hard dried carbon you usually find.
Also turns out I was wrong in thinking I had the vibratechnics dogbone mount, in fact I have the subframe mount and my dogbone mount is pretty badly split.
So that will be replaced and I will have the full set of 4 vibratechnics mounts.
Crank pulley and bolt was also replaced due to rust along with the new Cam belt and cam chain.
Engine overall seems to be pretty good which I'm obviously pleased about as I had never seen it run so was always a bit of a gamble.
Offline ChrisGT
« Reply #666 on: May 27, 2016, 11:51:55 pm »
Wow! what a difference on those inlets. How did you get them clean??
Cheers,
Chris
dansmith180
« Reply #667 on: May 28, 2016, 08:33:26 am »
Cheers,
Chris
Alex at AKS did it.
I believe he starts by scraping/ brushing what he can (possibly with some sort of cleaning solution) but the main thing is he uses a walnut blaster to get them mint.
Offline ChrisGT
« Reply #668 on: May 28, 2016, 12:08:55 pm »
Ah right, the walnut shell blasting seems to be getting quite popular, certainly looks like it works!
Cheers,
Chris
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #669 on: May 28, 2016, 01:06:26 pm »
Nice progress Dan.
Always a bit scary seeing just how much crap is deposited on the valves. Might look into this if and when I go hybrid or k04.
dansmith180
« Reply #670 on: May 28, 2016, 01:41:22 pm »
Nice progress Dan.
Cheers mate, definitely worth doing. Especially since you can do RFD/ carbon clean and uprated FPRV all at once and save some labour charges.
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #671 on: May 28, 2016, 01:43:54 pm »
Nice progress Dan.
Yeah that's what I'm thinking. Still a long way off for me though, got a few jobs to sort before I swap turbos.
I imagine the hybrid off the old engine is already sold...?
dansmith180
« Reply #672 on: May 28, 2016, 02:26:30 pm »
Nice progress Dan.
Not yet mate  :innocent:
dansmith180
Re: Dans grey MK5 GTI - soon to be BWJ powered - many things happening
« Reply #673 on: May 30, 2016, 07:54:26 pm »
So before the car went to Alex my gearbox was sticking around reverse/ 1st/ 2nd gear and never really worked right since it was fitted 5k ago. Well we found out why, here's a video of the play in the box
Also the clutch wasn't fitted 100% correctly  :doh:
Although it still seems in good nic but obviously isn't great.
This is pretty great though
Bulk of the new engine fitted  :jumpmove:  :jumpmove:
Vibratechnics mounts  :drool:, I will now have all 4 of them.
Still plenty of stuff to do but she's getting there.  :smiley:  :smiley:
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #674 on: May 30, 2016, 08:14:46 pm »
Great news Dan! Keep the updates coming! :drinking:
