Author Topic: Broken Vent - What Now?  (Read 2500 times)
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« on: September 14, 2014, 06:32:44 pm »
I had this on my old VW but it was an easy enough fix.
This one seems to have completely broken the clip.
It will sit in place but when I move it, it comes loose.
Any thoughts in fixing this? Do I need a whole new unit?
Offline simonp
  • -Receive: 38
  • No longer a Golfer
Re: Broken Vent - What Now?
« Reply #1 on: September 14, 2014, 06:38:02 pm »
Is it a side one or centre? The side ones are easy to remove, just pop off the dash side panel and push it out. I once bought a new one thinking the one in the car was broken like yours, but it all snapped back together once I had it out and could see what had happened!
*annoyed*
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #2 on: September 14, 2014, 06:45:53 pm »
From the photo there it's the middle one on the left side.
You can see it's not sitting right.
Think the actually rod that sits in the holder broke off
I remove the panel before she replacing the hazard but can't remember does that surround around the vents just click off or do I need to remove top vents and panel?
Offline simonp
  • -Receive: 38
« Reply #3 on: September 14, 2014, 07:14:44 pm »
The little slats just snap into place. Put some cloth over it and use long nose pliers to pull it back into its correct position. If it is broken then I think you have to replace the whole top dash, which is around 70 quid from memory. The interior was shagged on my car when I got it so I had to replace a lot of these parts!
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #4 on: September 14, 2014, 07:30:49 pm »
Yeah I'm sure the arms are snapped.
It does sit in place but comes out when moved.
I suppose I'm just being picky but still.... Since this has happened to me twice I thought it would be common so there might have been a DIY fix
Offline Webbmeister
« Reply #5 on: September 14, 2014, 08:54:05 pm »
Same happened to mine, bought a new centre unit for £55 from VW and sold the broken one on ebay for £10.  Fitting guides are on YouTube and only takes 10 minutes.
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #6 on: September 14, 2014, 09:05:30 pm »
£28 for the whole top section on ebay
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline PhilNUK
  • -Given: 32
« Reply #7 on: September 14, 2014, 11:21:05 pm »
I am after the right hand side little vent at the back of the arm rest for rear passengers.
The switch thing has come off and the slats inside are all a jumble
Offline DamoP
  • -Receive: 115
« Reply #8 on: September 14, 2014, 11:48:51 pm »
you need a new one. the bits cant be replaced. think i have a new one at home
Offline PhilNUK
  • -Given: 32
« Reply #9 on: September 15, 2014, 02:29:27 pm »
ah interesting.... do they come as a pair or can I just get the one side?
Even though I can't see it as a driver it bothers me it looks like that to passengers!
They easy to switch out?
