November 18, 2024, 11:41:19 pm
All Things Mk5
Mk5 General Area
seat loom
Topic: seat loom (Read 524 times)
stuupnorth
Always Involved
-Given: 10
-Receive: 3
seat loom
September 15, 2014, 01:08:06 pm »
Hi all
does anyone know the part number for the heated seat loom from vw
(fitting edition 30 seats)
cheers
Stu
RetroRaz
Just look at my post count
-Given: 32
-Receive: 194
Re: seat loom
Reply #1 on:
September 15, 2014, 02:15:36 pm »
Ive been looking to get one too, found a few people bought them from Kufatec if that helps ?
http://www.kufatec.co.uk/shop/en/volkswagen/golf/golf-5-golf-5-plus-1k/seat-heating-harness-vw-golf-5
#RetroRaz -
https://instagram.com/retroraz/
stuupnorth
Always Involved
-Given: 10
-Receive: 3
Re: seat loom
Reply #2 on:
September 16, 2014, 04:29:45 pm »
hi mate
yeah i know at that loom but it designed for lhd and some mods are required to fit i think with regards to the seat loom length
i thought buying a geniune VW loom would save the hassle
Stu
RetroRaz
-Given: 32
-Receive: 194
Re: seat loom
Reply #3 on:
September 16, 2014, 06:02:27 pm »
Hi Stu,
I think the only modification needed is to switch the under seat harness around from the passenger to the drivers side and vice versa.
Can someone confirm this is correct?
#RetroRaz -
stuupnorth
Always Involved
-Given: 10
-Receive: 3
Re: seat loom
Reply #4 on:
September 17, 2014, 02:55:50 pm »
Yeah I've heard that but does that mess around the air bags?
ie if you swap over the looms won't the airbag controller think you are in the passenger seat and if there is a accident the wrong airbag will go off??
can anyone clear this up please?
jason_rmh
Won't Shut up.
-Given: 69
-Receive: 81
Re: seat loom
Reply #5 on:
September 17, 2014, 03:30:39 pm »
With the kufatec loom you simply need to either:
Swap the seat looms over so controller is on drivers seat or cut / extend the loom so it can reach the passenger side where the heated seat controller lives.
Jas
VCDS (Preston, Lancashire)
stuupnorth
Always Involved
-Given: 10
-Receive: 3
Re: seat loom
Reply #6 on:
September 17, 2014, 05:45:17 pm »
so it doesn't affect the seat pressure sensor?
jason_rmh
Won't Shut up.
-Given: 69
-Receive: 81
Re: seat loom
Reply #7 on:
September 17, 2014, 09:23:57 pm »
If you swap the seat looms I think you'll have to code the occupancy sensor out, but it won't affect airbags.
If you cut / extended the kufatec loom, the occupancy works as normal which is what I did.
Jas
All Things Mk5
Mk5 General Area
seat loom
