Author Topic: Clutch and DMF Question  (Read 605 times)
Offline bakili
« on: September 15, 2014, 08:13:05 pm »
Hey guys
Got myself MK6 1.6TDI Bluemotion few days ago. Just noticed when I realise clutch pedal revs jump a bit (around 1k rpm) and drops back to normal after realised fully.
Car had new clutch and flywheel about 1 year ago at main dealer.
Is it normal clutch behaviour?
Sent from my iPhone
Offline th3_f15t
  • -Receive: 183
Re: Clutch and DMF Question
« Reply #1 on: September 15, 2014, 10:37:49 pm »
If you're on the accelerator at the same time it may be causing it. Best bet is to drive along, dip the clutch then quickly dump it (maintaining a constant accelerator pedal) and if the revs jump then something's not right. Do it with about 2500rpm going.
What that does is dump a load of torque onto the clutch, which isn't something you should do regularly if you want it to live a long, peaceful life.
Offline bakili
« Reply #2 on: September 16, 2014, 10:17:34 pm »
Thanks for advice
I am definitely not on accelerator, as it does it on idle parked up. I tried to clutch test with hand brake on and seems to be fine not slipping.
Sent from my iPhone
