Author Topic: Wing mirror puddle lights  (Read 11110 times)
Offline bbfb10
Re: Wing mirror puddle lights
« Reply #15 on: September 19, 2014, 07:46:17 pm »
My car oesnt have puddle lights, can these be retrofitted?
Full VCDS Hex + Can.
Offline ARV_90
« Reply #16 on: September 19, 2014, 08:11:01 pm »
To change them you push the mirror the wrong way and out pops a tiny screw hole to undo them. Its plug and play with no errors
Great thanks for the info... trigger pulled  :happy2:
Offline Bennz
« Reply #17 on: September 20, 2014, 12:04:56 am »
How do you actually change them ?
Offline ARV_90
« Reply #18 on: September 20, 2014, 08:38:42 am »
They can be retrofitted but you will need the mirrors and controllers, guy on here called EddieNL may be able to help if you drop him a PM.
Offline Stevie Steve
« Reply #19 on: September 28, 2014, 10:07:00 pm »
How about a ED30. Do I need to get the dremel out?
So do they plug and play and then need a recode?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #20 on: September 28, 2014, 10:31:48 pm »
My car never had the puddles fitted originally but they worked with just the coding. Cant tell if they will work until you plug them in though
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #21 on: September 29, 2014, 09:23:34 am »
So when you remove the cover did you have an empty socket so it's just plug and play?
Had to code through vcds yes?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #22 on: September 29, 2014, 01:05:27 pm »
I bought replacement mirrors with the puddle lights in them and just coded them in
Offline J12spk
  • VW PERVERT
« Reply #23 on: September 29, 2014, 08:37:17 pm »
Can't work this out, you got any pics?
Das Auto
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #24 on: September 30, 2014, 07:09:35 am »
Usually the wing mirror folds into the car, towards the window?
To get at the puddle light underneath, you push it towards the wing
Like this:
http://tinypic.com/view.php?pic=nfk588&s=7#.VCpI1N2kqK0
This is if you have the puddles existing in your mirrors obviously. If you dont you need to either dremel the space out and connect them or buy some mirrors with the puddle light in
Offline shaunnorris7
  • -Given: 18
  • 2008 GT TDI
« Reply #25 on: September 30, 2014, 09:23:17 am »
what type of bulb in needed??
Offline R9OSW
« Reply #26 on: September 30, 2014, 09:54:23 am »
Standard puddle light is just a normal 501 bulb.
Can either fit an led 501 or go for full led unit.
I bought full unit. Cars now like blackpool illuminations at night now :happy2:
Offline toosmiles
  • -Given: 22
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92286.0.html
« Reply #27 on: December 23, 2014, 02:06:38 pm »
Ordered them from aliexpress.com where they are a bit cheaper: http://www.aliexpress.com/item/2x-Error-Free-LED-Under-Mirror-Light-Puddle-Lamp-for-VW-Golf-5-Mk5-MkV-Passat/1830257334.html.
Thank you for the tip.
hey guys,
will these fit a golf R mk6?
thanks
Golf R mk6 R-tech tuned GTX3071r
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #28 on: December 23, 2014, 03:40:21 pm »
Offline toosmiles
  • -Given: 22
« Reply #29 on: December 23, 2014, 03:55:26 pm »
