Author Topic: Veyron VNS-VW Fitted and running  (Read 30942 times)
Offline chrisvectra
  • VXR IS FOR LIFE, NOT JUST FOR THRILLS
Re: Veyron VNS-VW Fitted and running
« Reply #30 on: October 18, 2014, 09:10:14 pm »
is there any pics to show me what u mean bud?
Offline chrisvectra
« Reply #31 on: October 20, 2014, 09:01:06 am »
Offline chrisvectra
« Reply #32 on: October 22, 2014, 08:49:39 pm »
anyone?
Offline chrisvectra
« Reply #33 on: February 23, 2015, 09:30:16 am »
im still none the wiser with this
I took the car to a audio shop and they tested the unit and said i need a new aerial which i bought I went to change that and the new aerial has a different end on it the the one thats fitted to the car. im told the aerial is the fakra connection and the new one i bought is a raku!
can any one help me please all i want is the radio reception to work on Fm as well as Am
Offline paulw123
  • -Receive: 47
« Reply #34 on: February 23, 2015, 05:26:07 pm »
Can you put some photos up of what you have?
Offline chrisvectra
« Reply #35 on: February 24, 2015, 07:10:02 pm »
thanks for replying fella..
I have the veyron unit fitted thats in the start of this thread..
The aerial on the roof is a shark fin and a vw unit.. the radio reception on FM is ok but stations drop out when on the move on AM there is no reception at all so no radio 5 live or gold!!
I took the car to a car audio shop and they removed the unit to test it and they said i need a new aerial which i bought this aerial however has a different plug on the end of its lead (a raku ) im told.
The shark fin aerial has a Fakra connection so now im totally confused..
ive read on here that theres different leads to fit but some work and some dont  powering the antenna etc so really unsure on what route to take now
Offline paulw123
  • -Receive: 47
« Reply #36 on: February 25, 2015, 10:31:30 am »
So have you fitted the connects2 adaptor lead linked to earlier?
I would have thought that would sorted out your FM problems  :confused:, the single blue wire powers the FM amplifier inside the metal box part to boost the signal, your current 2 aerial fakras plug in twin blue socket end, and single silver FM plug in back of head unit.
There are many types of VW aerials, with many different lead connectors.
Failing all else you may have to take to VW dealer  :ashamed: or let good car audio shop sort it all out for you.
Offline chrisvectra
« Reply #37 on: February 26, 2015, 02:10:01 pm »
Ive not fitted connects2 adaptor lead as ive read that these things dont make any difference to the signal
is there one you would recommend or know of that might work?
Offline paulw123
  • -Receive: 47
« Reply #38 on: February 26, 2015, 05:56:02 pm »
its only £9.75 delivered and further in this post member has used it and says it works, worth a punt  :popcornsoda:
I believe you need to amplify the FM signal, which this would......I've never herd of an aerial failing.....
Offline chrisvectra
« Reply #39 on: February 28, 2015, 10:40:59 pm »
I've ordered the lead fella and will see if it works or not
I will report back though fingers crossed
Offline chrisvectra
« Reply #40 on: March 03, 2015, 02:14:31 pm »
I fitted the connects2 lead this morning it seems to have made a slight difference to the FM signal but has done nothing for the AM signal.
bit of a waste of time and money really and i managed to scratch the climate control panel in the process!! :sad1:
Offline paulw123
  • -Receive: 47
« Reply #41 on: March 03, 2015, 05:35:11 pm »
oops sorry to hear that chris.
I wouldn't expect it to have any effect on AM, whats on AM anyway?
The connects thing helped with a sony unit with FM in the wifes MK4.
DAB is what you want anyway :grin:
Offline chrisvectra
« Reply #42 on: March 03, 2015, 07:56:37 pm »
mmmmmm id love Dab in the car but not that clued up in how it all works and if it would work with whats already in the car..
I listen to five live as well as gold on AM my other car picks this up no problem.
Had hopes this connects lead would sort it
Offline brinks787
« Reply #43 on: March 03, 2015, 10:55:19 pm »
I've got a very similar head unit to this one and the FM reception sucks,  if I put my Alpine unit back in the FM reception is perfect again.
My local car stereo shop who I trust confirmed that most of these units don't have great tuners built in.  A few they've found with the antenna connection poorly soldering inside. I checked this on mine and its soldered in place fine.
In the end I gave up and bought a Veyron V-Dab+ unit to get DAB radio.  It works perfectly and I get great reception even with the antenna just laid inside the car.  As a bonus it has a USB lead sticking out of it that I can use to charge my phone / ipad etc...
Offline chrisvectra
