Author Topic: Veyron VNS-VW Fitted and running  (Read 30957 times)
Offline brinks787
Re: Veyron VNS-VW Fitted and running
« Reply #45 on: March 04, 2015, 12:17:47 am »
Yep, thats the one.  It just plugs in the lighter/power socket and the antenna comes with windscreen suckers so you can run it behind the glovebox and up the a-pillar.
I didn't want to do that and rarely have back seat passengers so just ran the aerial lead along the centre console and up the back of the passenger seat.  I've looped the top of the antenna in a knot around the headrest supports.  You can't really see it and it works just fine that way.
There are some other more professional ones that you can hardwire in and plug into the aux-in of the stereo but they're a bit more pricey and a bit more of a faff.  It's worth giving the V-DAB+ a go to at least see if you get a decent signal in your area.  Buy it from Amazon and then you can always return it if you find there isn't much coverage in your area.
Offline chrisvectra
  • VXR IS FOR LIFE, NOT JUST FOR THRILLS
« Reply #46 on: March 04, 2015, 04:53:12 pm »
and this unit works well and picks up stations ok?
Offline brinks787
« Reply #47 on: March 04, 2015, 05:48:24 pm »
For me it does, 50 odd stations.  Although I only use it for a handful.
Offline chrisvectra
« Reply #48 on: March 04, 2015, 06:34:43 pm »
Would you do me a favour and see if it picks up Gold and radio 5 live before I order one
Offline paulw123
  • -Receive: 47
« Reply #49 on: March 05, 2015, 10:17:48 am »
Some other add on dab options here:-
http://www.dabonwheels.co.uk/Integrated_add-on_DAB_car_radios.html
personally I wouldn't want anything plugged into lighter socket. Some are hidden away with remote control, some work with vw steering wheel controls..
Offline chrisvectra
« Reply #50 on: March 05, 2015, 06:17:53 pm »
id prefer to have something hidden away but the glove box already has the tv receiver unit and the sub box unit as well..
I have ordered this so will see what happens lol
Offline chrisvectra
« Reply #51 on: March 11, 2015, 01:49:39 pm »
I bought one of these units coverage is fine but because the FM signal is so poor in the car this keeps dropping out and sounds worse then the FM.. I thought that this would plug into the Aux and play thru there but it come with a jack plug and the Veyron head unit only has a USB and a ipod connector
Offline brinks787
« Reply #52 on: March 11, 2015, 03:06:59 pm »
It does indeed.
You can check stations in your local area here though
http://www.ukdigitalradio.com/
Offline chrisvectra
« Reply #53 on: March 11, 2015, 06:11:50 pm »
Offline paulw123
  • -Receive: 47
« Reply #54 on: March 12, 2015, 10:28:00 am »
Get rid of it on ebay  :evilgrin:..........get yourself an rcd510 DAB  :P :P
Offline chrisvectra
« Reply #55 on: March 12, 2015, 12:39:07 pm »
this unit does it have tv,dvd,satnav reverse camera etc?
Offline chrisvectra
« Reply #56 on: March 15, 2015, 10:50:17 pm »
At my wits end with this now
Offline chrisvectra
« Reply #57 on: March 23, 2015, 11:38:24 pm »
Offline paulw123
  • -Receive: 47
« Reply #58 on: March 24, 2015, 10:43:42 am »
How about RNS315?
http://www.ebay.co.uk/itm/NEW-VW-RNS-315-DAB-BLUETOOTH-sat-nav-navigation-Golf-Passat-Jetta-Tiguan-RNS-510-/251358094615?pt=LH_DefaultDomain_3&hash=item3a861c2517
I don't think there is a battery drain issue with this headunit. Has Bluetooth and DAB in it, so a lot cheaper than adding these to RNS510, hopefully an expert will add more advice.... :sad1:
Offline Phil_H
« Reply #59 on: March 24, 2015, 03:59:33 pm »
I just picked up an RNS 315 with DAB for £175
Hopefully will do all I need :)
