Author Topic: RNS510 - screen goes black when I put car in reverse - 'safe to move'  (Read 1666 times)
Offline PhilNUK
  • -Given: 32
Hi guys.... as the title says I am getting that issue. It must think I have a reverse camera fitted?
It says 'is it safe to move?' or something similar
Is there an option to disable it?
Or is it meant to do it regardless of a camera fitted or not?
cheers
Offline Mk5Dom
Re: RNS510 - screen goes black when I put car in reverse - 'safe to move'
« Reply #1 on: September 19, 2014, 12:37:51 pm »
You'll need to turn RVC off in VCDS mate.
Offline PhilNUK
  • -Given: 32
« Reply #2 on: September 29, 2014, 11:58:23 am »
Hiya. Have done this today and it's still happening. The guy at Awesome GTI said it might need some wiring alterations?
Offline SI-R32
  • -Receive: 125
« Reply #3 on: September 29, 2014, 12:41:20 pm »
did you reset the 510 after making the changes in VCDS?
Offline PhilNUK
  • -Given: 32
« Reply #4 on: September 29, 2014, 12:47:08 pm »
The guys at the specialist did it and not sure if they reset. I will do that though. Just the two arrows and star button?
Offline SI-R32
  • -Receive: 125
« Reply #5 on: September 29, 2014, 12:50:21 pm »
Yes that's all it should need, you always need to reset 510 after any changes in VCDS to take affect
there will be NO wiring issues at all, its all software driven , awesome are probably used to after market stereos where you have extra wiring to know if the cars in reverse
Offline PhilNUK
  • -Given: 32
« Reply #6 on: September 29, 2014, 01:24:56 pm »
Cheers mate! That sorted it!
Offline Mk5Dom
« Reply #7 on: September 30, 2014, 08:18:59 am »
Good stuff!
Sent from my blower using Tapatalk.
