September 20, 2024, 12:07:06 am
All Things Mk5
Technical Workshop
Lower control arm - Part numbers for bolts needed
Topic: Lower control arm - Part numbers for bolts needed (Read 1698 times)
ChrisGti
Just Arrived
-Given: 0
-Receive: 0
September 19, 2014, 10:24:17 pm »
Good evening Gents, Does anyone know what the part numbers are for the bolts on the lower control arm rear bushing bracket? It uses 3 bolts per side, of which two are the same.
I think they are M10 & M12.
SI-R32
Just look at my post count
-Given: 8
-Receive: 125
Re: Lower control arm - Part numbers for bolts needed
Reply #1 on:
September 20, 2014, 09:28:58 am »
do you mean the console bush bracket bolts
http://thumbs2.ebaystatic.com/d/l225/m/mtWASvyRhIfQgI3PcxFpcqg.jpg
if so 12mm is N 91039802
10mm is N 10579702
ChrisGti
Just Arrived
-Given: 0
-Receive: 0
Reply #2 on:
September 20, 2014, 08:52:50 pm »
Yes! Thanks a million.
All Things Mk5
Technical Workshop
