Author Topic: Good or bad mpg ??  (Read 9416 times)
Re: Good or bad mpg ??
« Reply #15 on: September 23, 2014, 03:00:35 pm »
seems pretty good to me. 28mpg @ 100 mph is good
If that indicated speed was a read out off his speedo then he was only doing around a 'true' 90mph.
Offline th3_f15t
  • -Receive: 183
« Reply #16 on: September 23, 2014, 04:11:42 pm »
I thought the police and law enforcement can only prosecute you if they have a video/picture that clearly shows your number plate or some other definitive way to identify your vehicle? It's why I blur all number plates in my pictures that I post (both my car and others) so that's identity is that bit harder from a legal point of view.
But as with everything, not advisable to advertise law breaking so clearly. Better to say "was going a fair speed :wink:" than clearly state your speed, despite the difference in speedometer readout and actually true speed (via GPS tracking) it'll still draw attention from the law.
We all like to put our foot down from time to time, just be careful when and where!
« Reply #17 on: September 23, 2014, 04:57:49 pm »
Had my Edition 30 2 weeks and it's averaging 30mpg at the moment.   I've come from an R32 which weighed 140Kg more, had a 1.2 litre bigger engine, made the same power and it averaged 26mpg.
I thought the whole point of FSI was it's economy?  :grin:
« Reply #18 on: September 24, 2014, 09:57:05 am »
The TFSI doesn't do full stratified injection like the n/a petrols.
Offline Stevepd
  • -Given: 49
« Reply #19 on: September 24, 2014, 12:02:07 pm »
I'm getting 31ish @ 70 on my 32 mile commute, which pops up to around 38 when @ 60 for the same journey, also don't forget the official combined MPG for a standard car in a lab is 39.4mpg so anything above that you're doing well.
« Last Edit: September 27, 2014, 08:55:41 am by Stevepd »
Standard 5 Door Shadow blue.
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #20 on: September 24, 2014, 12:45:34 pm »
Mine seems to do around 40MPG at 70MPH.
Stage 1.5 K03 (Pre-cat delete)
130k miles
Tesco Momentum
18 inch wheels @ 40 PSI Eagle F1 AS2's
Oil and Filter every ~8k
Offline th3_f15t
  • -Receive: 183
« Reply #21 on: September 24, 2014, 01:04:36 pm »
40 PSI? :confused: I thought the recommended was 29-31 PSI..?
« Reply #22 on: September 24, 2014, 04:21:05 pm »
I didn't realise there were different levels of stratification?   I thought any FSI motor with the HPFP and direct injectors fully stratified the fuel, otherwise what's the point?  May as well rip it out and go back to port injection.  At least the intake valves would be cleaned!
Offline TurboHatchback
« Reply #23 on: September 24, 2014, 06:04:03 pm »
My GTI is completely standard on 17s with Goodyear Eagle F1 Asymmetric 2 tyres, Castrol edge oil and always run on V-Power. I average 32-38 on short urban runs and 40-42 on longer runs. On a blast down the autobahn averaging 100mph and peaking at 125 it averaged 30.7mpg over about 100 miles. Once I did a 20 mile round trip and managed 46mpg average (there was a lot of pensioners out that day).
I think the economy is really good for what it is, not so good on <5 mile trips but when warm I am quite pleased how good it is.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #24 on: September 24, 2014, 06:22:23 pm »
My old gti i got it to 39.8mpg driving at 60mph on the m1. highest i ever saw it lol
Offline samg77
« Reply #25 on: September 27, 2014, 03:07:50 am »
I'm Stage 2 DSG in my Edition 30 so running about 340bhp with full Milltek TBE and i would average about 18mpg at that speed so would only get around 230 miles to a full tank of around £75ish. :sad1:
Offline th3_f15t
  • -Receive: 183
« Reply #26 on: September 27, 2014, 10:00:52 am »
40 is fine for the 18's, you can run about 45 PSI with load / passengers.  Less drag better economy.
I've found 36-38 is better for comfort though.
I'm sure they'd take 100PSI++ before popping. :evilgrin:
Checked mine and the tyre shop filled them to 34psi. I stand corrected!
Offline NOONSY
« Reply #27 on: September 28, 2014, 10:41:44 pm »
i was a way for the day so my old man decided to take my car up to my nans in shrewsbury 160 mile round trip cruise set 65 all way up m6 he got a 46.5 mpg average. he did to prove a point that it wold do more than 40 to prove a point   :indifferent:.
Offline GTiBlues
  • Mr Blues
    • Bookface
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
« Reply #28 on: September 29, 2014, 07:29:29 am »
Sat on cruise control at 70 I can get around 450 to a tank, or average of something like 41mpg. I've only got stage1 at the moment
Offline akbarirfan
  • -Given: 81
« Reply #29 on: September 29, 2014, 11:42:42 am »
Hi All,
According to the Kwik-Fit tyre pressure search, the below table shows what pressure we should inflate our tyres to - do you agree?
Tyre Size    Front (BAR)  Rear (BAR)   Front (PSI)   Rear (PSI)
225/45R17     2.2 BAR       2.0 BAR           31 PSI   29 PSI
225/40R18     2.0 BAR       2.0 BAR           29 PSI   29 PSI
