Author Topic: ok I know......  (Read 757 times)
Offline stuupnorth
    • stuupnorth
ok I know......
« on: September 22, 2014, 11:11:46 am »
Ok guys
the chestnut......which oil would be best for my 2005/6 gti
it's done 110k the oil has been changed regularly is it time to use 5w-40
or stick to the 5w-30?
by the way it's bog  standard
cheers
Stu
Offline th3_f15t
  • -Receive: 183
Re: ok I know......
« Reply #1 on: September 22, 2014, 11:52:26 am »
I've started using 5w-40 as it's able to deal with higher engine temperatures seen on turbo charged engines (if I'm correct). If you like to use the full rev range, perhaps 5w-40 would be better long term, but otherwise there's little, if any, different at standard tune.
Correct me if I'm wrong though, I only know the real basics.
