Author Topic: Squealing engine issue please help  (Read 2086 times)
Offline Drapoon
« on: September 22, 2014, 01:20:57 pm »
So I've had a problem develop on my trusty old 07 gti which I've had from almost new and put 66k on...
I have an intermittent squeal which has developed, it sounds like a squealy bearing, almost always carries on whining once ignition is switched off and before the drivetrian comes to a hault.
Switching off / on air con does not have any effect
Sometimes I dont hear it at all on a short journey and other times it is very loud. My mother in law thought I had squeaky brakes when I dropped my son off to her this morning.. and that's the best way to describe it.
It does sound like it is coming from the starter motor which is odd as I would only expect this on start up from a sticky solenoid?
Other than that I am stumped.
I've read up on the usual faults of diverter valve and pcv, this car has had neither done but then again I ran vag.com on it only last month and no fault codes at all...plus this isnt a symptom of either of thsoe failing from what I gather
Shall I change this anyway as a matter of course?
Things I can think of of the top of my head which need elimianting are:
Water pump bearings
Alternator bearing
Some sort of vacuum leak
Noisy fan bearing
any ideas people?
cheers
Martin
Offline th3_f15t
  • -Receive: 183
Re: Squealing engine issue please help
« Reply #1 on: September 22, 2014, 04:17:57 pm »
All I can say is the DV and PCV won't throw up fault codes of their own usually, something else will eventually so best inspect/replace as a matter of cause.
Possible help to hunt this squealing is to be in the engine back and listen to components to see if it's obvious.
Offline xjay1337
  • -Receive: 377
« Reply #2 on: September 22, 2014, 05:14:26 pm »
Probably aux belt, alternator or cambelt or one of the associated tensioners / pulleys
Offline doylebros
« Reply #3 on: September 22, 2014, 07:23:05 pm »
Offline gixerben
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92657.msg930393.html#msg930393
« Reply #4 on: September 22, 2014, 08:31:22 pm »
My Pirelli started to squeal and I changed the PCV and sorted it.
Car ran fine and it first sounded like a aux belt slip, but after I switched the car off I could hear hissing so took the plunge and was worth it..
Pirelli GTI
Offline Drapoon
« Reply #5 on: September 25, 2014, 01:32:26 pm »
cheers guys
I have come to the conclusion it's the pcv. I've bought a new one & shall be fitting this eve
fingers crossed!
