Author Topic: Accessing the MFD on highline clocks without a MFSW?  (Read 5805 times)
Offline Georrge
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,93533.msg937034.html#msg937034
Re: Accessing the MFD on highline clocks without a MFSW?
« Reply #15 on: February 24, 2015, 09:40:24 am »
Hi George,
Sorry to bring this ancient thread back up, but wondering if you found a solution to this issue? I'm having the exact same issue, I recently upgraded from midline to 972 Highline clocks, I don't have mfsw and can't access mfd via my stalk driving me insane.
No need to apologise, that's what the admins on here want you to do!
But as far as I'm aware, the solution is to get a MFSW. I'm planning on getting s mk6 wheel, just waiting for the right one to pop up  :happy2:
Instagram @george_kersh
Offline rex
  • -Given: 50
  • -Receive: 74
« Reply #16 on: February 24, 2015, 09:48:38 am »
Hi George,
Same here. I am having the same problem...
It appears you might need a highline CCM, but that didn't work for me: http://www.mk5golfgti.co.uk/forum/index.php/topic,93756.msg943026.html#msg943026
Offline Georrge
« Reply #17 on: February 24, 2015, 11:31:11 am »
Hi George,
Interesting, I never knew you could change them. Let me know if you get it working or not later!
Offline Rukz
« Reply #18 on: February 24, 2015, 02:53:38 pm »
Thanks for the info guys, this issues really annoying. I'll be installing a mfsw in the near future, but I was hoping I could still use my stalk to access the mfd for now! Damnit
If you guys come to find a solution give us a shout. Cheers
Tornado Red | MK5 | GTi | DSG
Offline xjay1337
  • -Receive: 377
« Reply #19 on: February 24, 2015, 03:20:55 pm »
I don't think you need a highline CCM..
on my old 1.9 TDI it was a 2004 se with cruise control etc.
highline cluster fitted and controlled from indicator stalk no issues..?
 :ashamed:
Offline Rukz
« Reply #20 on: February 24, 2015, 03:23:02 pm »
 :ashamed:
Then why don't it work for me  :sad1:
Offline Georrge
« Reply #21 on: February 24, 2015, 03:23:54 pm »
 :ashamed:
It depends on what clocks you get from what I've been told. I have cruise control too, but can't access menu
Offline xjay1337
  • -Receive: 377
« Reply #22 on: February 24, 2015, 03:24:19 pm »
did you try a different indicator stalk....?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #23 on: February 24, 2015, 03:34:50 pm »
if you have a later style cluster, wiper stalk wont work. you will need a mfsw. Happenned to me on my 973 clocks. on my old golf I had a 971 cluster and wiper stalk worked.
Offline Rukz
« Reply #24 on: February 24, 2015, 03:39:25 pm »
Hi raz,
The cluster I got installed is a 972, so it should work shouldn't it? The SatNav instructions appear on the mfd (directions, compass etc) however, track info and radio info doesn't and I can't access the mfd via stalk.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #25 on: February 24, 2015, 03:42:17 pm »
Hi raz,
what happens when you hold the up or down position for about 5 seconds?
I thought u had a 973 fitted?
Offline Rukz
« Reply #26 on: February 24, 2015, 03:52:00 pm »
oh sorry I mentioned 973 to you, but that was my mistake, it's a 972 cluster off Jedi's 55 plate GTi.
Holding up/down for about 5secs does nothing, just the same as if I was to press it once up/down (go to the next item ie. mpg, range etc)
Offline Rukz
« Reply #27 on: February 25, 2015, 03:43:46 pm »
From the research and reading I've done on this issue everything seems to indicate that I should be able to access the settings menu etc especially considering that its a 972 cluster and not a later 973/4 cluster.
Could it possible be just a coding error? The vehicle the 972 cluster came out of had mfsw and mine doesn't. Hmm
