Author Topic: Rear Air Vents  (Read 1423 times)
Offline bakili
Rear Air Vents
« on: September 23, 2014, 08:02:42 pm »
Hey guys,
Air vents which build in handrest are smashed up on my car. Seen brand new ones are selling under £12 but how can I change them? Anyone has how to or easy guide?
Many thanks
Sent from my iPhone
Offline burger187
Re: Rear Air Vents
« Reply #1 on: September 24, 2014, 12:18:59 pm »
If u have the cup holder at the back too flip it open there should be torx screws, just undo them and pull the back part from the armrest. When u put the vent in make sure it's flush
Offline bakili
Re: Rear Air Vents
« Reply #2 on: September 24, 2014, 10:11:21 pm »
Thanks for reply
I opened cup holders and could see two torx screws. Removed them and could remove cup holders only. There are another two torx screws on bottom, visible after cup holders removed, but I think they do attach armrest to the floor.
Sent from my iPhone
Offline burger187
Re: Rear Air Vents
« Reply #3 on: September 25, 2014, 11:40:21 am »
Open the cup holder. There are two T20 torx screws in there. Remove them and lift the arm rest up. The trim should come out toward you at the bottom and lift upwards to release the top part. I think the vents are secured by melting plastic pegs on the trim. The pegs fit through holes on the vent and are then melted over the holes to secure the vent in place, which is OK if it's a new trim but on an old trim the pegs will already have been melted to fit the original vent. Copied from another forum
