Author Topic: White marks of turbo wheel  (Read 1800 times)
Offline danc1706
« on: September 25, 2014, 07:42:02 pm »
Had my turbo checked out today to see if the seals had gone on it but turns out they are fine, the bloke who looked at them said my car was running lean as there were white marks on my turbo wheel, anyone know what the cause of this is as the car is standard (edition 30)
ED30 stage 1.5 330bhp 328ftlb
Re: White marks of turbo wheel
« Reply #1 on: September 25, 2014, 08:08:00 pm »
I would do some lambda logs to verify that there is a problem with running lean if a vcds scan doesn't flag up a faulty lambda sensor .
Offline danc1706
« Reply #2 on: September 25, 2014, 08:18:10 pm »
Ok cheers, would a k&n air filter effect it, it was on there when I bought car! But surely the ecu would detect the air flow on the car and put more fuel in?
« Reply #3 on: September 25, 2014, 10:10:14 pm »
Yup, the ecu should adapt to the increased airflow and alter the fuel mix accordingly.
Offline danc1706
« Reply #4 on: September 25, 2014, 10:28:19 pm »
Ok cool so if it doesn't adjust then could mean faulty lambda sensor
« Reply #5 on: September 25, 2014, 10:36:19 pm »
A faulty lambda sensor is one of the possibilities.
Like I said before, getting a scan will get you a long way into solving your issue.
Offline danc1706
« Reply #6 on: September 25, 2014, 11:01:13 pm »
Ok cheers, my mate has a vag com so that should work?
Offline Pikey Motorsports
« Reply #7 on: September 28, 2014, 02:39:46 pm »
What made you think you had turbo issues?
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
« Reply #8 on: September 29, 2014, 04:10:55 pm »
My Garrett GT35R turbo looked like that after 60K miles (from new) on an old project of mine.  The turbine blades were in A1 condition.   Modern turbo engines run leaner than the 80s gas guzzlers.
The ED30 has EGT (Exhaust Gas Temp) backup where the ECU will shove a load of fuel in if it detects excessive exhaust temps, but check for EGT related fault codes just in case.
If you can get hold of VCDS (formerly known as VAG-COM), log the following blocks and go out for a 20 minute drive: "Lambda Regulator", "Lambda requested",  "Lambda actual", "MAF", "Boost requested", "Boost actual" and "Ignition advance".  Paste into Excel and then upload to here.  I will be able to tell you from that if you have a problem or not.
Offline danc1706
« Reply #9 on: October 02, 2014, 01:37:59 pm »
It was smoking slightly on let off!
Offline danc1706
« Reply #10 on: October 02, 2014, 01:39:54 pm »
Ok I will try get hold of my mates vag com and have a look
