Author Topic: had the car terracleaned.  (Read 4259 times)
Offline lady_gti
« on: September 28, 2014, 07:52:22 pm »
Took the car for my 1st terraclean on Friday. I was a little bit sceptical like most people about having this done. I've done a lot of reading about how to get rid of my carbon build up as it's been running really rough and idling being painful so needed to do something asap.
Wow I wish I had done this sooner, the terraclean only took 2 hours and such a brilliant service. I've driven around a lot over the last few days and I've noticed a massive difference. It's like driving a brand new car, no more rough running, bad idling, horrible starting and occasional misfires. Will see if anything changes over the next few weeks.
Reflex silver GTI, revo intake, eurojet dogbone mount and insert, colour coded rear bumper, projector headlights, revo stage 1, precat delete, cente resonator delete, R8 coilpacks, eibach sportlines, depo projectors, 4300k hid kit... Not finished yet
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: had the car terracleaned.
« Reply #1 on: September 28, 2014, 07:54:21 pm »
Did you have the intake system done or just the standard fuel system?
Offline Matthewsimone
  • -Receive: 39
« Reply #2 on: September 28, 2014, 08:13:16 pm »
Whats it involve and rough cost please mate  :jumpmove:
Offline lady_gti
« Reply #3 on: September 28, 2014, 08:22:43 pm »
I had the intake and fuel system in what they call an intensive clean that set me back £176 all in. They recommend the intensive clean 1st and then standard cleans annually.
« Reply #4 on: September 28, 2014, 08:36:45 pm »
I am sure @Saintsteve had this done a while ago and said it did nothing to his engine as its a tfsi engine but could be wrong
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #5 on: September 28, 2014, 08:42:19 pm »
^ @Saintsteve  only had the fuel system clean done IIRC. They weren't doing the intake clean for some reason. I think the intake clean would give the best results on the TFSI
Offline lady_gti
« Reply #6 on: September 28, 2014, 08:52:24 pm »
The clean I had done was specific to direct injection engine. Maybe they have developed the service.
Offline BarberVW
« Reply #7 on: September 28, 2014, 09:13:00 pm »
How do I locate somewhere that can carry out this work?
Black 3 Door Manual | Bi-xenons | Winter pack | Luxury pack2 | Cruise control | Highline display | MFSW | 18" Monza 2's | Armrest | Glovebox MDI | Blue tint glass
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #8 on: September 28, 2014, 09:26:40 pm »
http://www.terraclean.co.uk/
I also had the intake clean done by terraclean and noticed a good difference !
Another fella i know won a free tearraclean, he own's a 182 clio, and noticed a huge difference, better idle, his fuel went from 25mpg to 32mpg over 2-3 days...
Silver is the way !
Offline th3_f15t
  • -Receive: 183
« Reply #9 on: September 28, 2014, 09:30:43 pm »
From what's been said before, the intake clean does make a difference, but best results are gained when you remove the inlet and walnut shell blast the inlet ports on the head properly. The standard Terraclean isn't worth it as mentioned, get the full intensive treatment.
It's on my to-do list.
Offline chris1440
« Reply #10 on: September 28, 2014, 10:10:56 pm »
I had my gti terracleaned a couple of weeks ago.  I had  rough idling and poor starting.  (Power was down but that was due to the diverter valve).  It did make a difference, idling was smoother, engine was quieter, starting was better and fuel economy went up by 2-3 mpg.  Then I had my DV replaced which made a hell of a difference!
Offline muff1991
  • -Receive: 69
« Reply #11 on: September 29, 2014, 01:26:52 pm »
Lady_gti - what mileage / age is your car, mine is 64k/2006 and have been thinking about this as well, not sure whether to leave it a bit longer or not, I don't really experience any issues with idling but know it wouldn't hurt at all to have it done :)
Offline lady_gti
« Reply #12 on: September 29, 2014, 01:47:52 pm »
My car is a 57 plate and has done 79000. From what I know about my cars history, as I've only had her since March, is the last owner was from London so I can imagine it's been doing a lot of town driving which doesn't help.
Offline muff1991
  • -Receive: 69
« Reply #13 on: September 29, 2014, 02:57:45 pm »
ok cool, mine was only driven about 8 miles a day at one stage in its life hence low ish milage
« Reply #14 on: September 29, 2014, 04:47:56 pm »
VW dealers sell a fuel cleaning additive which is supposed to work quite well on TFSI injectors.  Anyone tried it?
Mine too, if just to see the walnut shrapnel in action  :smiley:
The other (and cheaper) way I've seen people do it is close both valves on TDC and scrub the ports and valves with carb cleaner.  My only concern with that is cleaner and bits of crud dropping down into the bores and washing the oil off.  Walnut shells would just burn off harmlessly I suspect.
Some folk squirt stuff in through the intake air sensor hole.  Does that get good distribution across all 4 cylinders and the tumble flaps?
