Author Topic: Fitted new downpipe...flat battery, and now a sensor fault  (Read 2278 times)
Offline Rob.
« on: September 29, 2014, 06:15:32 am »
I managed to get my new downpipe fitted a couple of weekends ago, but struggled to get the post-cat lambda sensor off of the old exhaust.
When I finally removed and re-installed that, I tried to start the car on Saturday and it was dead. I ran VCDS, which gave a load of low voltage warnings (and checked the batt with a multimeter) so left it to charge for a few hours, then she started fine.
However, I've now got a couple of faults that won't clear: "engine oil temp sensor - implausible signal" and "sensor for engine oil level/temperature - opens or short to plus". The dash also warns about it when starting up.
I don't recall doing anything to these during the work (only the O2 and MAF were unplugged), so is it possible the low voltage has somehow killed it?
Thanks.
Offline Rob.
Re: Fitted new downpipe...flat battery, and now a sensor fault
« Reply #1 on: October 03, 2014, 07:52:09 am »
No one?  :scared:
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=cbata4sf04u9hl3j7mjsrntn3e&/topic,90967.msg917089.html#msg917089
« Reply #2 on: October 03, 2014, 07:56:18 am »
Sometimes i find some errors won't clear when you use clear all errors. And i have to go into that block to clear the error.
05 | Tornado Red | DSG
Offline DDM
« Reply #3 on: October 11, 2014, 08:13:52 pm »
they just might of been there before you fitted the new down pipe? when was the last time you ran a test before then,
Offline Rob.
« Reply #4 on: October 12, 2014, 06:13:58 pm »
Definitely wasn't, as it's actually saying "oil sensor garage" on the dash when I start her up...wasn't doing that before the flat battery!
Offline Rob.
« Reply #5 on: November 15, 2014, 02:21:56 pm »
Yeh, so basically I must have unplugged the oil sensor plug and forgotten to put it back in  :sad1:
Awkward.
Offline edd30
« Reply #6 on: November 18, 2014, 11:10:55 am »
All sorted now ? Was it just the oil level sensor ?
Think the low voltage problem is unrelated to what you did.
