November 27, 2024, 02:45:13 pm
All Things Mk5
Performance Modifications
Cam Follower - Reinforced Version?
Topic: Cam Follower - Reinforced Version? (Read 7888 times)
akbarirfan
Won't Shut up.
-Given: 81
-Receive: 18
September 29, 2014, 02:48:44 pm »
Hi All,
I just spoke with Roy from Autobarn here in Basingstoke, I want to replace the cam follower in my car and he advised that there are uprated cam followers around - does anybody have any experience with them? Or where to buy them from?
I want to got to Stage 1 and would like to not have to replace these every 10-15k miles!!
Also does anybody know which gasket/seal is required when doing this job? I believe it is the Fuel Pump gasket but not sure.
This one maybe..
http://regal-auto.co.uk/shop/fuelling-upgrades-c-3_85_88_495_690/oem-vag-hpfp-seal-20-t-fsi-p-856.html
Thanks,
Irfan
Last Edit: September 29, 2014, 02:54:20 pm by akbarirfan
anorganix
Re: Cam Follower - Reinforced Version?
Reply #1 on:
September 29, 2014, 03:04:07 pm »
Uprated version?! Would be nice!
When replacing my CF, I always replace this seal also: WHT 005 184.
Hope to help!
Later edit 1: found
this
(VW FSI Performance Cam Follower) and
this
(KMD Uprated Cam Follower).
Later edit 2: seems that there is a recall for failing CFs - Audi TSB 150702.
Last Edit: September 29, 2014, 03:18:03 pm by anorganix
GrayMK5GTI
Global Moderator
Just look at my post count
-Given: 125
-Receive: 248
Reply #2 on:
September 29, 2014, 03:18:06 pm »
In the UK you don't need to replace every 10-15k. Realistically every 50k, unless very highly tuned or used for heavy track use. Most people just stick with OEM.
I've never replaced the seal, and never had a leak.
warby
Always Involved
-Given: 1
-Receive: 4
Reply #3 on:
September 29, 2014, 04:08:29 pm »
Having seen and repaired an mashed cam I'll be changing mine every 10-15k. It's only 30 quid.
pudding
Global Moderator
-Given: 2
-Receive: 690
Reply #4 on:
September 29, 2014, 04:53:29 pm »
There's 2 upgrades available:-
This one -
http://hpfpupgrade.com/Products/Show/Volkswagen/2.0T+FSI/VW+FSI+Performance+Cam+Follower
And a kit from INA Engineering which replaces the cam follower with a roller follower from the TSI engine.
Neither are proven, so the best bet is regular oil changes and check the follower every 2nd oil change. It's not a lot of work to change and cheap. So far there isn't a better, permanent, solution.
akbarirfan
Won't Shut up.
-Given: 81
-Receive: 18
Reply #5 on:
September 29, 2014, 08:00:16 pm »
Thanks guys - have ordered the Cam Follower and O-ring from VW - £39 in total FYI.
anorganix
Reply #6 on:
September 30, 2014, 07:43:44 am »
I think BDM used the roller follower in their S3 build.
They say that this kit is a "fit and forget" solution to the high maintenance, problematic OEM fuel pump drive system.
Last Edit: September 30, 2014, 07:46:33 am by anorganix
All Things Mk5
