Author Topic: What's needed to fit r32 bucket seats  (Read 2809 times)
Offline Chris92
  • -Given: 33
« on: September 30, 2014, 06:49:20 pm »
As the title really what will I need to change to get r32 buckets to fit without airbag light etc, is it just 4 bolts, unplug and lift old seats out?
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
Re: What's needed to fit r32 bucket seats
« Reply #1 on: September 30, 2014, 09:51:34 pm »
And make a resistor to stop airbag light coming on.
Seat wiring plugs may have changed between an early and a late car but im not 100% on that
Offline Gti_Mad
« Reply #2 on: October 01, 2014, 09:15:06 am »
I'm sellin a set in the next week or so
As said above u need a resistor Alex at Aks can provide them tho  :happy2:
Offline xjay1337
  • -Receive: 377
« Reply #3 on: October 01, 2014, 09:55:40 am »
You don't normally need resistors.
Genuine seats have built in resistor packs so you can plug them straight in.
The airbag plugs can be different. Although usually you are fine as you just need to trim a part of the clip to make them fit and disconnect fine.
Offline Chris92
  • -Given: 33
« Reply #4 on: October 02, 2014, 10:04:27 pm »
Thanks guys  :happy2: I found a set on ebay from a guy breaking one, and the price is very cheap maybes too cheap tbh compared to what I see them go for. He either doesn't know what he's selling or something is dodgy with them
Offline Gti_Mad
« Reply #5 on: October 03, 2014, 07:14:44 pm »
Nice mate are we Talkin stupidly cheap or reasonably cheap lol
Offline Chris92
  • -Given: 33
« Reply #6 on: October 04, 2014, 07:28:14 pm »
Silly cheap  :laugh:
Offline th3_f15t
  • -Receive: 183
« Reply #7 on: October 04, 2014, 07:48:31 pm »
My R32 buckets did have a connection, but it's different from my standard GTI's one so I needed the resistors. You can buy them for about £2 each on eBay, just make sure to get the right resistance!
Offline xjay1337
  • -Receive: 377
« Reply #8 on: October 04, 2014, 07:59:05 pm »
The ones you need are 2.1ohm from Maplins, around 15p each... know maybe it's nice to have to lack of worry and the cost is small but it's the principle haha.
Yeah the seat plugs can be different.. depending on which way you only need to trim a small bit of plastic off the clip itself .. my Recaros are from an S3 and fitted straight into my Golf, however the plug on the Scirocco was slightly different so we had to trim a bit of non-essential plastic, and they work fine.. The Scirocco seats in the Golf were a bit harder but again only needed trimming of the plug.
And wire them in like this.
« Last Edit: October 04, 2014, 08:00:49 pm by xjay1337 »
Offline th3_f15t
  • -Receive: 183
« Reply #9 on: October 04, 2014, 08:20:52 pm »
Cheers for that. I've got me some pre-made resistors to plug into my car's wiring loom to trick the airbag module into thinking an airbag is present, then will clear the airbag light and all good!
