Author Topic: HPFP banjo bolt delete.  (Read 8352 times)
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=jcs197klreoahrr5ftl3obr5uj&/topic,90967.msg917089.html#msg917089
« on: October 01, 2014, 02:56:04 pm »
The banjo bolt on the HPFP is a pita.
Can the banjo bolt be replaced with something easier to get off. I remember reading you can replace with flexible hose is this possible?
05 | Tornado Red | DSG
Re: HPFP banjo bolt delete.
« Reply #1 on: October 01, 2014, 03:23:12 pm »
In addition to the rubber hose you also have to replace the metal fuel lines and swap the banjo connector brass fitment for a bamboo connector.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #2 on: October 01, 2014, 03:44:11 pm »
Do you think this is worth doing? Anyone done it?
« Reply #3 on: October 01, 2014, 04:10:25 pm »
I've done it!   :evilgrin:
Got the fuel lines with rubber hose off ebay so just needed the brass bamboo connector and a couple of VW clamps.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #4 on: October 01, 2014, 06:06:38 pm »
So you replaced both solid pipes banjo and the other one?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #5 on: October 01, 2014, 06:18:35 pm »
I will need this??
06F127509AB Metal fuel line
06F127511B Fuel hose
06F127213C FP metal union
N909865 01 X 4 spring clips
Anything else?
« Last Edit: October 01, 2014, 06:28:29 pm by dazza »
« Reply #6 on: October 01, 2014, 07:25:13 pm »
The metal fuel line is the most expensive part so unless you can source a cheap second hand one from a breaker's yard I wouldn't bother.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #8 on: October 01, 2014, 10:13:46 pm »
Found this on ebay.
http://www.ebay.co.uk/itm/2009-AUDI-TT-2-0-TFSI-FUEL-LINE-PIPE-06F127509AB-/231184944962?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item35d3b24f42
Anything else i would need?
Yes, iirc you will need the rubber hose 06F 127 511 B to connect to the hpfp bamboo connector (you will need this brass connector but I don't have a part number) and three N 906 867 01 vw spring clamps. One of the clamps is to replace the one on the hose for the N80 purge valve, the other two for either end of the  06F 127 511 B rubber hose.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #9 on: October 02, 2014, 08:58:28 am »
I've ordered the fuel line. Will i need to remove the intake manifold?
@bacillus thanks for your help with this.
Offline Danbear79
« Reply #10 on: October 02, 2014, 09:34:23 am »
Just out of interest, why do you find it a pain in the ass?   I replaced my cam follower recently, and the only troubling I had was doing the nut up on the fuel line next to it. Do these banjos fail, or do you want to change it because it's easier to remove the hpfp?
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #11 on: October 02, 2014, 10:07:17 am »
It took me about 15 minutes to remove the HPFP 12 minutes remembering with socket, extension and ratchet to use. There is a reason they did away with the banjo bolt if it's a cheap easy fix i will do it.
« Reply #12 on: October 02, 2014, 10:34:11 am »
You can install this without removing the intake manifold. You may need a crows foot to loosen the nut that fastens to the pvr that's on the underside of the manifold.
Offline dazza
  • -Given: 90
  • -Receive: 190
  • Coding Boffin
« Reply #13 on: October 02, 2014, 11:05:52 am »
Great so with the crows foot is should be easy? Any idea on the size?
« Reply #14 on: October 02, 2014, 11:23:24 am »
Can't remember the exact size but when you get the fuel line, you can check the size of crows foot needed as the line comes inclusive of the nut.
